SL55/63/65/R230 AMG: tires for my '09 sl63
Old Apr 10, 2013 | 09:09 PM
photonut's Avatar
SL63
michelin no longer makes the oem rear tires for my '09 sl63
i need a single rear tire to replace one with side wall damage.
the oem is a michelin ps2 285/30ZR19.
any suggestion on how to find a replacement?
Old Apr 10, 2013 | 09:27 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
ebay
Old Apr 10, 2013 | 09:34 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Have you checked with a local Mercedes-Benz dealer? They might still have a few in a warehouse somewhere. Failing that, there's probably no way to safely replace just one tire. Sucks, but there it is.
At this point, unless your rear wheels are 10" wide, Michelin doesn't have a solution for R230 AMG SLs with 19" rims. I've been looking for tires for my 2008 SL55 and am not thrilled with the options I've found so far.
Old Apr 20, 2013 | 04:22 AM
photonut's Avatar
SL63
ebay has only worn out used tires.
the dealers do not stock the tires and recommended run flats instead.
turns out michelin still makes a ps2 in a 295/30ZR19 size which fits the same rims.
i just had them installed
Old Apr 20, 2013 | 07:31 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
My 2008 SL63 came with Pirelli P Zero, these were designed for the car and
have an extra inner wall to stop it wiggle when accelerating.
Good luck
Old Apr 21, 2013 | 10:34 AM
photonut's Avatar
SL63
Good luck
thank you for that info. i will for sure be getting pirelli's when my michelins wear out.
Old Apr 21, 2013 | 05:59 PM
okbarnett's Avatar
Gee , I see 11 of them on ebay. I must have been wrong.
Old Apr 21, 2013 | 06:24 PM
tajaro's Avatar
sl63
Brand new 295/30-19 ...
http://www.ebay.com/itm/1-NEW-Michel...41c28a&vxp=mtr
Also new 285/30-19 ...
http://www.ebay.com/itm/1-NEW-285-30...253db4&vxp=mtr
Old Apr 22, 2013 | 06:07 AM
photonut's Avatar
SL63
Originally Posted by tajaro
those (and all the other new michelin ps2 tires available on ebay and elsewhere) are "285/30 ZP 19" tires.
mine were "285/30 ZR 19".
the ZP designates zero pressure (run flat).
michelin sells these ZP pilot sport 2's as a replacement for the older non-run flats.
