SL55/63/65/R230 AMG: A step back !
Old May 5, 2013 | 07:25 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
A step back !
Whilst everyone is striving to put multi clutch gearboxes in their cars, why
Have MB gone back to a auto box when the previous SL 63 had a MCT box.
I imagine it's because it won't take the torque from the V8 TT engine.
Does that mean all the competitors have low torque engines. Mind you they
Have improved the action of the auto box, but still not as good as my previous
SL63 MCT box. Surely they can design a MCT box that will take the torque.
Old May 5, 2013 | 08:17 AM
rune solem's Avatar
SL 55 and a GT 3000 vr4 Here's my car: http://home.online.no/~ludvs/index.cfm
Gearbox
I've heard that the double clutch add some weight, maybe that's why?
The new bmw with the dual gearbox has 500 lt ft, so it's a considereable lower output for the gearbox to handle.
So it may be easier for mb to make an tested and proven gearbox instead of designing a completely new dual clutch to handle 590 lt ft.
Did the mct gearbox in your old car shift as comfortable as in the new one?
Old May 5, 2013 | 11:23 AM
Wolfman's Avatar
Super Moderator
I guess they can't.
ZF's latest dual clutch can handle 516 lb/ft of torque, so not enough for the new 63...
Old May 5, 2013 | 01:20 PM
JumpinJim's Avatar
SL63
The 2013 SL63 does have the MCT.
Old May 5, 2013 | 01:50 PM
DCMETRO22Z's Avatar
E320
Thank you ! I was starting to Think I were mad.
The 2013 SL63 HAS A MCT GEARBOX wich is NOT a double clutch transmission like Porsche PDK, BMW DKG, Audi S-Tronic and many more.
IT'S AN UNIQUE KIND OF TRANSMISSION.
Basically that's a 7G-Tronic transmission where the traditional Torque converter has been replaced by a wet startup clutch.
Do not confuse it with the SLS amg transmission wich is a real Double clutch trans.
"The use of the exact terms is the most beautiful poetry"
Late French president François Mitterand.
Old May 6, 2013 | 08:09 AM
sound 8's Avatar
Sorry guys your wrong, it has a torque converter, and described in the
brochure as Auto.
As I said, they have done some work on it, and it's better than the old auto.
Actually it need not be 7 speed, if you put it in manual it stays in 5th most of the time up to about 70, it wont change to 6 or 7 until your going over 70ish.
My previous 63 did not do that, maybe 7th not available at 60, but I think
it was geared for 19 inch wheels with 30 profile. My new 63 has 20inch rears
still with 30 profile tyres so it must be geared up as the normal wheels are 19
with 30 profile tyres.
Old May 6, 2013 | 08:50 AM
absent's Avatar
GT63S ePerformance 4dr, '25 Bentayga Black Ed.(wife), Wrangler and 250 MLB(kids)
brochure as Auto.
No,you are wrong (as many times before).
A quote from MB press release at the 2013 SL premiere:
" Mercedes' AMG Speedshift, a seven-speed automatic transmission that uses a wet clutch pack in place of a traditional torque converter and sports four shift modes."
NO TORQUE CONVERTER IN SL63!
Now read it 100 times so it will finally get through to you.....
Btw,the same tranny is in 2011(and newer) S63 and 2012 CLS63/E63
Old May 6, 2013 | 09:17 AM
JumpinJim's Avatar
SL63
brochure as Auto.
You're reading the info for the SL65. The 65 uses the 7 speed auto transmission. The 63 uses the MCT. Visit the AMG site and you'll see.
Old Aug 20, 2013 | 10:34 AM
sound 8's Avatar
Does the 2013 SL63 have the same gearbox as the 2009 SL63 N/A
Old Aug 20, 2013 | 10:40 AM
sound 8's Avatar
You say that the 2013 SL63 does have a Multi clutch transmission.
Then you say the SLS has a double clutch which is different.
Can you explain, I am interested.
Old Aug 20, 2013 | 04:56 PM
carlsturm's Avatar
DCT's can handle torque. Ref Bugatti Veyron
