SL55/63/65/R230 AMG: good read on maintenance diy
Old May 19, 2013 | 04:00 PM
overZealous1's Avatar
sl55 amg
found this while looking for some info online. good read with lots of diy info. even a article on swapping out the abc suspension. yup, strutmasters has a kit for the sl500 that should work on the sl55 if the fix it light is turned off in the ecu. option is already there due to the black series, just need to have it turned off.
http://www3.sympatico.ca/gmacgruer/_MB_SL55_AMG.pdf
Old May 19, 2013 | 06:54 PM
RAWAMG's Avatar
SL55 AMG EC Stage 5 Beast / ESS S/C E92 M3
I have contacted Strutmasters about that kit in the past... They say it isn't for the SL55 BUT I can't see why it won't work They have a "Light Fix Module" that they sell for the light issue BUT I betcha you could do it through STAR.
Old May 20, 2013 | 09:45 PM
BobLibSL55's Avatar
2004 SL55
Im bumping this because it should be at the top. Maybe even sticky.
Thanks for the link.
Old May 20, 2013 | 10:30 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
sticky!
Old May 21, 2013 | 05:13 AM
RAWAMG's Avatar
I agree STICKY - This was a great find Scott! I just sent moderator a PM for sticky.
Old May 21, 2013 | 12:11 PM
sl55 amg
pretty amazing how much info is packed into that pdf.
Old May 21, 2013 | 03:45 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
If the car has ABC suspension you will need to remove the ABC pump and put a fixed idler pulley in it place.
If the car has airmatic you will able to use the SM kit and code the car to steel susepnsion.
Old May 21, 2013 | 06:19 PM
sl55 amg
it is a combo pump for ps also. it looks like you can just cap the lines going to the original struts and turn the abc light to "black series" in star and it won't light up. you could swap the pump, but it sounded like the single pump that would fit would come from a sl65 black series or a maybach. probably not cheap!
the springs in the strutmasters kit is eibach, so you could call them to get different spring rates at about $75 a spring if you wanted to change rates.
for me, i am so low i use the ride height button an average of every 10-15 minutes. so i am going to keep the abc on mine. all is in great working order and no leaks so far!
Old May 21, 2013 | 08:28 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
You would need the power steering pump from a black series not a fixed idler to retain power steering
Old May 23, 2013 | 09:12 AM
RAWAMG's Avatar
This thread has been posted in the already "STICKY' DIY on this board.
Thanks Rock
