SL55/63/65/R230 AMG: SL New wheels
However, as per subject - 275/30-20 on 11" wheels - I stand by what I stated. I said safely and properly, meaning recommended by tires' manufacturers - 10" is max for 275/30-20, while 11" is recommended for 305/25-20.
275/30 on 11" is a major stretch for tires with usual for the size section width (10.9") and extreme for those few narrower section width (10.5"). I do not know which brand of tires you have nor for some reason can zoom into the pictures to see.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Gonna put my lightweight 19" wheels on pretty soon...
