SL55/63/65/R230 AMG: SL65 Intakes, Suggestions
I've been looking at the air boxes and slightly bigger intake pipes Renntech has but for the HP gain vs cost I feel like its a waste.
I know Speedriven has a scorpion intake, but my biggest concern is heat soak
I was thinking maybe do something like the Brabus setup they have for the SL65 since I'm getting the body kit put on in late march/early may and the intakes look like they go right where the air scoops are on the hood
But then I saw this recently on Speedriven and I was thinking, this could very much solve the heat soak issue
What do you guy's think?
Juha
This is my take on this...if I relocate my horns and remove the 2 small support rods up front, 2 filters would fit, HOWEVER, the intake inlet hole on the drivers side is obscured by 2 lines that cannot be moved, at least very easily. Frustrating, but I think I will see decent results with not a lot of money spent...
a puddle could be consumed. When you don't expect it.
Because I own an M5E60 also I found this…. maybe one solution? Modified to fit SL R230.
http://www.evolveautomotive.com/arti...ent-continues/
But sure, anythng can happen. Not worried...
