SL55/63/65/R230 AMG: star diagnostic errors? pics attached
Old Mar 31, 2014 | 03:58 PM
CHADisBAD's Avatar
G63
Question star diagnostic errors? pics attached
so i picked up an SDS for my 03 SL55, and was giving the program a "test drive".
i ran a quick check, and this is the list it came up with. does anything appear unusual, or i should be concerned about??
Attached Thumbnails star diagnostic errors? pics attached-sds-1.jpg   star diagnostic errors? pics attached-sds-2.jpg   star diagnostic errors? pics attached-sds-3.jpg
Old Mar 31, 2014 | 04:30 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
all lower case f are stored but not current all upper case F are current fault codes.
Old Mar 31, 2014 | 04:32 PM
CHADisBAD's Avatar
G63
ahhh
ahhh, so all those 'f' was previous codes, that had been corrected sometime in the past? if so, can they be cleared?
what does the 'I' and check symbol represent?
Old Mar 31, 2014 | 04:41 PM
shardul's Avatar
yes you can clear them.
i = communication issues with that module
Old Mar 31, 2014 | 04:44 PM
CHADisBAD's Avatar
G63
hummmm, communication issues. is this normal to see on most SDS programs?
Old Mar 31, 2014 | 04:52 PM
shardul's Avatar
no
you can can get into each module from the control units menu
Old Mar 31, 2014 | 05:57 PM
Benz-O-Rama's Avatar
Since it's your first time scanning it, I'd just clear the whole list of faults and start fresh. Drive it for a week and rescan.
Old Apr 1, 2014 | 11:03 AM
CHADisBAD's Avatar
G63
thanks...
i cleared out all previous faults, and re-ran the check. everything was showing good. i will run another check in about a week or two, and see if i develop any new faults.
i was also about to perform the fan suction modification to +10 Celsius. thought about lowering it via SDS, but im going to hold off for now. i do not want to throw out my alignment, and have inner tire wear.
next step is to try and figure out where the octane settings are? if you know, mind shooting me a PM with those steps
thanks for the help/advice guys.
Old Apr 1, 2014 | 12:18 PM
JadAwada's Avatar
SL55 AMG
Beware of lowering the car using the SDS, it will put a big stress on the ABC System, I suggest you buy lowering links
Old Apr 1, 2014 | 12:24 PM
shardul's Avatar
Ok you statement does not make any sense. I am not even going to try to argue with you.
manipulate the voltages physically or via SW has the same end result.
Old Apr 1, 2014 | 12:33 PM
JadAwada's Avatar
SL55 AMG
@shardul, I'm just telling him what I've been told by my workshop, he said preferably lowering should be either using an electric lowering module, or Lowering links. And he said lowering using the SDS will put stress on the ABC system.
There's no need to argue anyway, we are all here to share our points, and help each other.
Old Apr 1, 2014 | 12:52 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
What are those systems going for now ?
Old Apr 1, 2014 | 01:00 PM
My ECU is tuned by Eurocharged, so I've never had to worry about the octane maps. Honestly, for the insane low prices Eurocharged's tunes are now, there's really no reason not just have them tune it, and call it a day.
The same physical stress to the suspension system will be the same, regardless of method of lowering. I'd recommend links, for the ease on wallet vs. the pricier lowering module. If you're someone that likes to fiddle with ride height all the time, then the module is your best bet.
Airmatic cars, SDS all the way. ABC suspension, the less you disturb that sleeping monster, the better, IMO.
BTW, my car is lowered via SDS, which didn't give it much of a drop. I added link on top of that, and I'm right were I want to be.
Old Apr 1, 2014 | 01:18 PM
CHADisBAD's Avatar
G63
suspension
do you have any camber or toe issues, causing inner wear on the tires?
Old Apr 1, 2014 | 01:28 PM
do you have any chamber or toe issues, causing inner wear on the tires? do you have any chamber adjustments>
Yes, on the camber issues. You lower these cars at all, and you're gonna chew the inner part of the tires. These cars don't allow for much in the way of camber adjustments. If you're not ready to replace tires every 8K-10K miles, stay at stock height.
Here's the ride height I'm at:
https://www.vossenwheels.com/CarGall...VSCV3-622.aspx
Old Apr 1, 2014 | 01:52 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
When we first started lowering cars via the Star system, we used my '03 SL55. I want to say it's been lowered for around 9 years and there have been zero ABC issues.
I firmly believe that the secret to avoiding issues and prolonging the life of these components is changing the ABC fluid. I've had the car since new and have performed regular fluid changes and the car remains bullet proof!
Old Apr 1, 2014 | 04:28 PM
^^^^^ THIS.
It's not something that you really think about until something bad happens. I've changed mine, zero ABC issues. Well, except for when one dyno shop put the rear straps OVER the ride height sensor arms and snapped em when they tightened her down. That was an oopsie, nothing related to a system failure.
Old Apr 1, 2014 | 04:36 PM
shardul's Avatar
i have seen that happen so many times!!
Old Apr 1, 2014 | 07:09 PM
seven_out's Avatar
SL500, Miata
It means the code for an "event" is stored in controller memory.
Be sure to post back with the details of where you purchased your SDS and what setup you have including whether or not you have a "development" version which provides access to non-standard menus.
Old Apr 1, 2014 | 07:14 PM
busaboy's Avatar
2004 SL55
Where did you buy the SDS system? What comes with it?
Old Apr 1, 2014 | 09:02 PM
CHADisBAD's Avatar
G63
Setup came with laptop, Multiplexer, serial to OBDII and RS232 cables. The software is version 7/2011 (2011-06-15) includes Xentry, EPC, WIS, etc.
I purchased the setup from a member on here a few weeks ago, that sold his E55.
Old Apr 1, 2014 | 09:41 PM
seven_out's Avatar
SL500, Miata
Why send a PM when the information can be shared with everyone? Send me a PM if you know.
Here's the path:
Control Units > Motor Electronics > Adaptations > Correction Programming > Ignition
Old Apr 1, 2014 | 10:36 PM
CHADisBAD's Avatar
G63
Here's the path:
Thanks for that info. Not sure if I have development version, how would I check?
Old Apr 2, 2014 | 07:47 AM
seven_out's Avatar
SL500, Miata
One of the first screens you see upon starting the software will be a screen warning that your SDS is a "Developer Kit". The attachment shows the exact text that appears on my SDS.
Old Apr 23, 2014 | 10:03 AM
CHADisBAD's Avatar
G63
Question
Rod... do you know what menu i need to go into, to stop the automatic volume adjustment, when speeding up and slowing down? i cannot stand it.
