SL55/63/65/R230 AMG: New SL55 owner
Old Jun 2, 2014 | 10:45 AM
fxrs1955's Avatar
2014 SL550
New SL55 owner
Traded my 500 for a 2007 SL55, what a difference. I'm thinking about installing the Eurocharge Stage 1 kit and was wondering if anyone has any experience with this company.
Thanks in advance
Old Jun 2, 2014 | 12:50 PM
JohnH's Avatar
2004 SL55 AMG
Have had the Eurocharged remap and SC pulley fitted and very happy. Make sure you also replace you IC water pump and fit the additional Heat Exchanger as you might suffer from SC overheating. I have a 2004 SL55 and even though it was fast before it it a lot quicker and smoother now. Fortunately I have also fitted an LSD so able to put the power down. Enjoy your SL55.
Old Jun 2, 2014 | 04:02 PM
kittyandgary's Avatar
2003 SL55 AMG
I too have installed the smaller SC pulley, the belt wrap kit, and had the Eurocharge tune to my '03 SL55 (bought it in July 2013). It IS quicker, and I like the change. All in all, it's very straight forward to do (changed 12 year old serpentine belt, while doing this). I had to heat the head of the Supercharger pulley bolt to get it to come loose, but everything else was straightforward. Be sure you have the Bosch IC pump with the last two digits '10', not the one with those as '03'.
Old Jun 2, 2014 | 07:20 PM
cal1's Avatar
SL55, ML500 & Acura TL
Eurocharged (EC) is a respected bunch on this forum. Tons of the E55 guys run EC stuff. I have an EC dyno tune. Definitely look into the smaller SC pulley. In the older days of modding, slippage was an issue so most went to a bigger counter pulley (me included) to over spin the SC. It creates more rotating mass and some counter pulleys have had issues staying on. Also, as the guys mention above, our motors are very susceptible to heat soak which robs power like crazy. Adding an additional heat exchanger reduces this issue.
Old Jun 2, 2014 | 11:25 PM
vtvette's Avatar
2005 SL55 AMG
If I read the Eurocharge site correctly Stage 1 kit raises power to 557hp and 617lb ft torque!?
Does anyone know if the dyno is at the wheels?
For $1500 that is a smoking deal! It appears this includes an OBDII flash tune as well?
Old Jun 3, 2014 | 06:43 AM
DangeRuss's Avatar
2003 SL55
What does that include? Link?
Old Jun 3, 2014 | 06:53 AM
fxrs1955's Avatar
2014 SL550
I spoke Jerry at Eurocharge and he recommends the stage one kit and I'm going to use his idler pulleys as well. The stage one kit comes with 180mm crank pulley kit,an i/c pump,new heat exchanger and ECU reflash. All in all in a good deal.
Old Jun 3, 2014 | 09:47 AM
cal1's Avatar
Are you asking if the quoted increase in power is at the crank or wheels? If so, I am guessing the 557HP and 617 Torque is at the crank. I have mods beyond stage one and the last dyno showed about 490 HP and 540 torque at the wheels.
Old Jun 3, 2014 | 11:39 AM
fxrs1955's Avatar
2014 SL550
I spoke With Jerry at EUROCHARGE again and the crank pulley does not come with the kit, it was a website error. The crank kit is 400.00 extra.
Old Jun 3, 2014 | 11:54 AM
cal1's Avatar
That being the case, have you considered the smaller SC pulley instead? IMO it is the best way to go. If you still want more boost after that, you can add a larger crank pulley. You would then need a new tune, but one of the cool things about EC is that additional tunes are free.
Old Jun 3, 2014 | 12:08 PM
fxrs1955's Avatar
2014 SL550
The smaller S/C pulley is included, it's the crank pulley that's extra.
Old Jun 3, 2014 | 12:54 PM
cal1's Avatar
Thanks for the clarification. That is a nice package at a great price.
Old Jun 3, 2014 | 01:00 PM
JohnH's Avatar
2004 SL55 AMG
Had it installed by Jerry from Eurocharged US and Paul from Eurocharged UK on his recent visit to UK. Great guy and very knowledgeable!!
Old Jun 3, 2014 | 09:16 PM
fxrs1955's Avatar
2014 SL550
It's still a good deal, I'm going to install it in a month or so. Thanks again for the sound clip on the cat delete, definitely doing that too.
And for anyone on the fence about moving up to a 55, it's worth the money.
Old Jun 4, 2014 | 06:23 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
your 2007 has the upgradet Bosch 010 intercooler pump and the 80 mm upgradet trottle body, and probaly best model and last with compressor engine..
Old Jun 4, 2014 | 07:51 AM
fxrs1955's Avatar
2014 SL550
I knew about the throttle body but not the pump. I'm thinking about running another heat exchanger in line with the stock unit.
Old Jun 4, 2014 | 09:37 AM
cal1's Avatar
Glad to help.
Old Jun 4, 2014 | 11:57 AM
i have the Johnson pump sitting, but i think the bosch 010 is doing the same ting, so not needed change that one . Inline is the ting to do yes with the extra intercooler , You need look that for shure y have the upgraded pump
Old Jun 5, 2014 | 03:08 PM
Georgee6086's Avatar
1994 E500, 2012 e63
To the OP I would start with a good set of long tube headers and ecu tune
