SL55/63/65/R230 AMG: I need help, very confused
Old Jun 6, 2014 | 10:29 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
I have read loads of items concerning ic pumps inc " pictures for Nick
Between my coolers ( aluminium boxes at the back of the engine ) I have
a cap, just like a radiator cap. I also have a valve on one pipe like a bike wheel that should have a cap as my 600 does.
When they say bleed the system do you join a pipe on to the valve, and
where is the reservoir to drain fluid to. Do I need to take off the cap to fill
the systems, It is so difficult without pictures.
Help would be appreciated.
Old Jun 6, 2014 | 10:37 AM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
The instructions on how to vent the IC system is here: https://mbworld.org/forums/sl55-amg-...ml#post6063102
Old Jun 6, 2014 | 11:49 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
http://www.benzworld.org/forums/arti...-pictures.html
Old Jun 6, 2014 | 03:08 PM
sgaar's Avatar
That was a great post, thanks. Just one thing remains....getting the correct/recommended IC pump. I have been reading about different kinds, but Bosch seems to be the 'winner'.
My question is if this is the correct pump?: http://www.autohausaz.com/search/pro...20Water%20Pump
If it is not the correct pump with the higher capacity, can someone point in the right direction on where to get it?
Thx,
EDIT: In case the pictures for the post disappears, I have printed it out to a PDF.
File Type: pdf
Old Jun 6, 2014 | 03:14 PM
sound 8's Avatar
Thx,
+ 1 and many thanks to all you guys.
Old Jun 6, 2014 | 03:32 PM
JohnH's Avatar
2004 SL55 AMG
Thx,
Yes thats the latest Bosch pump.
Old Jun 6, 2014 | 03:49 PM
sgaar's Avatar
OK, so with that being the newest pump, I am looking the pictures of the pump and cannot see where the vent tube goes.
Old pump:
New pump:
Is that just to plugged or does it go somewhere else?
Old Jun 6, 2014 | 08:32 PM
theintelligent1's Avatar
SL55
the new pump just has a dummy part on top there (the silver metal notch) to put the vent tube........this is part of the design change for the new pump....freaked me out when i did mine too
Old Jun 12, 2014 | 11:02 AM
sgaar's Avatar
I figured that changing the IC pump would be easy, no big deal. I ordered the pump, got it, took the cover off the bottom of the car, and...... failure!
On my '07, there is no way to get to the pump unless you take half of the car apart...well, the bumper need to come off.
I look like when MB did the facelift starting in '07, they changed more than just the bumper and such. Some of the internals was also moved around. The pump can be seen from the bottom, but you cannot get to it.
I have attached some pics and as you can see, it is inaccessible.
Attached Thumbnails I need help, very confused-20140612_093229_android.jpg   I need help, very confused-20140612_093241_android.jpg   I need help, very confused-20140612_093258_android.jpg
