SL55/63/65/R230 AMG: In the shop - Smartop
I have the car in the shop today. New brakes and rotors, smartop being installed, etc, etc.
They've installed the smartop and sent me a short video but I notice that when in operation the lights on the mirrors flash until it's complete. Does anyone know if that is by design and/or if it's programmable to switch it off?
TIA
TIA
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Not sure, never tried.. I would imagine a good Tech can.
I read it was a warning indicator in the event it is activated mistakenly and clearance to open or close is an issue.. It's letting you know something is about to go honorably wrong!!
2006 Scion XB, BMW 335D, Porsche 997TT, 1997 Jeep Wrangler, 1974 Vespa, 2011 Cayenne, Diamond DA40
Smart Top
You should be able to disable the light flash in the smart top setup. Function 1, setting 2 should give you what you want. It's a little complicated trying to explain how to access the setup menu, but the full directions are available on the smart top web site. www.mods4cars.com
What shop did the install for you?
You will love the smart top. Nothing like putting up the top when it starts to rain without having to pull over and stop. The remote function is cool too.
I'll hook it up to the computer when I play top down tonight!
Well, it's been 75 degrees here in Atlanta today so the top will be down when I finish up at the office in about an hour!
Well, I don't see a way to program it via the steering wheel buttons and I'm not sure if that could be because of my modded stereo with functions that use the in dash programming.
That said, it's very easy for me to plug in the usb cable that's been installed and use the programming matrix from here; http://www.mods4cars.com/m4cupdate/i...BMZ1#ma_anchor
I have the latest firmware flashed to the module and I have these settings flashed on the module; 1, 2, 2, 2, 2, 3, 1, 0, 1, 1.
Things appear to be working as designed except the chirp on lock and the flashing hazards when the smartop is in operation.
Some have said that its normal and others say that the hazard light flashing can be turned on and off in the matrix so what am I missing?
Any advice guys? TIA
take a closer look at the function/settings matrix
you want to set function 1 to setting 2.
"I have the latest firmware flashed to the module and I have these settings flashed on the module; 1, 2, 2, 2, 2, 3, 1, 0, 1, 1."
try these settings; 2, 2, 2, 2, 2, 3, 1, 0, 1, 1
enjoy!
enjoy!
enjoy!
enjoy!
enjoy!
enjoy!
I still have no joy on function 6. My horn, etc works like normal but I get no chirp. I've tried changing the function 6 from setting 3 (chirp on unlock/lock) to setting 6 which is siren but still no luck.
It looks like I need professional help!!! Thanks for the suggestions.
RoundTheBenz, i'm not sure i understand your chirp situation. my setting is 2 for funtion 6. the term "chirp" is a little misleading. my horn "honks" on unlock, which i've done so i can hear it so i don't hit unlock too many times and roll down the windows or open the roof by accident. do you want to turn it on/off or are you expecting an actual "chirp"?
Exactly what I want is for the horn to beep on lock and unlock how you describe.
you have the correct settings and have updated the firmware. i would take it back to where you had it installed and let them troubleshoot it, or if you have time on your hands, you can contact mods4cars & try and troubleshoot it your
self. there is a diagnostic mode in program.
I think I've found the solution but I haven't had time to try it yet but I thought I'd post anyway. I'll let you know when I get to it.
http://www.mods4cars.com/support/kno...php?article=29
