SL55/63/65/R230 AMG: 2007 SL65 confused on new rotors ????
Why the big difference? I could understand the other way around with sport costing more....... but why would mine cost so much more without?
Also all the after market ones I see are not 2 piece like mine, is there really a difference with the 2 piece compared to 1 piece? From what I see I can only get the 2 piece from the dealer at 1100 each.
Thanks!!!
I think they are looking at parts for SL55/SL600. NOT SL65... But they still have it TOTALLY Backwards... The 030 (Sport )Package on the SL55 has the 390MM TWO PIECE Rotors and 19 inch wheels exactly like the SL65.
I think that there are aftermarket suppliers that will sell just the rotors and bolt kit (not Hats) for much less the the MBZ Stealership...
I think that even Brembo might sell just the rotors which if you are patient you can remove/replace the old rotor bolts...
Here are the part numbers you'll need based off of my invoice:
rear
x1 brake pad set 005 420 25 20
x1 brake pad sensor 171 540 06 17
x2 brake disc 230 423 12 12
front
x1 brake pad set 004 420 84 20
x2 brake disc 230 423 14 12
