SL55/63/65/R230 AMG: SL65 Starter Battery affect performance?
BTW - the consumer battery and starter battery are on separate systems. If your starter battery is completely dead and the consumer battery is 100% charged you are not starting the car.
However, on an r230 the starter battery does not act as such. As you noted, we have two batteries. Except during emergency situations (weak or dead systems battery) they are separate and isolated from one another. The consumer/systems battery is the primary, supplying power to all vehicle systems (ecu and ignition included). The starter battery's sole purpose is to spin the stater motor. Changing it won't alter the engines performance other than if it will be able to crank over or not as it simply doesn't power anything else...
R230 battery system overview;
http://www.benzworld.org/forums/attachments/r230-sl-class/265471d1255206253-pdf-repository-r230s-dual-battery.pdf
There is some logic to what the Porsche guys told you. On some performance vehicles the alternator is clutched, its actually shut off on high throttle positions to reduce load and maximize engine output, running the car straight off battery and the alternator acting as an idler. Another method that is now more common on modern cars with Ecu regulated alternators is for the ecu to simply turn off the regualtor so the alternator drag is far reduced (although the engine is still spinning the mass unlike a clutched alt)
On cars like these there could be a potential performance difference for a weak battery vs a strong one as when the alternator is shutoff the ecu and more so the engine ignition coils are using the battery alone for current. However even in these cases it's the ecu that contrs the alternator, and will only do so with sufficient battery voltage which is monitored continuously.
The r230 sl65 doesn't use a clutched alternator, and again the starter battery wouldn't be the one supplying current here so once again there is performance change to be found through the starter battery.
but if you are right and all I have to do is detach the starter battery for 2 minutes and reset the adaptive that is great.
And I never said all you have to do is disconnect the starter battery for a couple minutes to reset the adaptive functions. What I did say is that your adaptive functions were most likely *somehow* reset during the battery swap which would best explain what you experienced. As I explained in detail a new starter battery simply would not alter engine performance, as it does not power anything besides the starter motor except in low battery operation (with dash warnings to go along)
I'm not sure what you want to hear? Sorry you don't find people 'here' helpful but on this topic people 'there' don't know what they're talking about
I watched the battery swap. Nothing was done other than swapping out the battery so "somehow" didn't happen.
I think you took me wrong. I asked for input. I joked when I got none.
I think I will trust my AMG Certified mechanic. His opinion is that anything that is running "weak" on these cars will affect them.
I'm still thankful for all input.
What you saying I got a bad rap over here? I can't think of anything I have done that would bring that on.
