SL55/63/65/R230 AMG: SL65 HE
Old Jan 16, 2017 | 11:39 AM
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
SL65 HE
Hello.
Can someone help me out?
I need a picture about the HE at SL65?
My car is an SL600 and I know it's smaller than SL65.
I also wonder if the SL65 HE is "bolt on" at the SL600?
I want upgrade my HE intercooling. I have already Eurocharged HE but I want more.
Thank you.
Juha
Old Jan 16, 2017 | 05:04 PM
boostd's Avatar
2005 SL65
If you already have an upgraded HE, your next cooling step is split cooling. I did this with a trunk tank from Rhodes Racing.
Old Jan 16, 2017 | 05:13 PM
Ekselent's Avatar
Yes... thats true, but I want also bigger OEM HE also so I wonder if the SL65 HE would fit.
Old Jan 16, 2017 | 10:36 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Trunk tank is gonna cool the car alot better. One of the best mods I did on my 65
Old Jan 18, 2017 | 06:31 PM
Ekselent's Avatar
Okey thank you..
Look. I found this info. Mercedes SL65 AMG Black Series Heat exchanger located like this. Two piece. One at the left side and one at the right side. Big ones.
So why not for the wide body cars? The tunnels is also there... it must be very effective solution.
Old Jan 20, 2017 | 02:11 AM
AMG-Driver's Avatar
SL65 R230
Ekselent, in the Sl65 Single Turbo Conversion - Thread in this section, you can see some pictures of the 65 cooling package in the front.
Old Jan 20, 2017 | 02:41 AM
DUDMD's Avatar
2005 SL65 AMG, 04 S600
I believe the stock HE on the SL65 sits between AC condenser and Radiator. Mine has an aftermarket additional HE right in front, seen in one of my pics in the single turbo build.
Old Jan 20, 2017 | 10:22 AM
Ekselent's Avatar
Yes I think you have right.
Thank you.
Old Jan 20, 2017 | 10:23 AM
Ekselent's Avatar
Thank you....
I'm gone look at that...
Old Jan 25, 2017 | 08:00 AM
Ekselent's Avatar
I have decide to go this BS route.
Today I have asked from two different manufacturer offer's of two "cross flow" heat exchangers.
My opinion is the locations is the best of all. No heat from the engine.
Old Jan 25, 2017 | 07:24 PM
euphoriaDSM's Avatar
SL65 AMG
Take the HE out and run killer chiller.
Old Feb 1, 2017 | 05:30 PM
Ekselent's Avatar
At some point I thought that to... but I decide to go this "BS" route + OEM HE in the middle.
Old Feb 22, 2017 | 06:16 PM
Ekselent's Avatar
AMG Driver.
Can you ask your tech one question regarding the SL600 fuel pump. I know you have an SL65 today. I have try contact Pierburg but no answers.
The OEM SL600. I have measure the pressure and it's show at idle and at 1,5 bar boost the same pressure. 3,8 bar.
Normally, the pressure should increase by the same amount from 3,8 bar to 5,3 bar. I don't want waste money to buy a new pump if the pump its not broken. The SL65 Fuel pump charts show its gone do that. From 13,5 Volt 300L/h to 20 Volt 360 L/h.
I'm 100% sure I need more fuel. Its run to lean after 4600 rpm.
Thank you.
-Juha
Old Feb 23, 2017 | 06:13 AM
AMG-Driver's Avatar
SL65 R230
Hello Juha, I'm not sure if this is your question but when I remember correctly SL600 and SL65 have different pump control systems. You have to find someone with access to WIS System from MB to understand the difference to the AMG. The SL600 pump will not deliver enough with the 600 fuel pressure system, so my former tech switched to SL65 Pump and it did well and safe up to 330 KM/H.The rest was in the ECU, no bigger injectors. I think if you change your injectors you really need someone who can recalibrate your ECU and who has insight how your fuel control system works.
