SL55/63/65/R230 AMG: MB STAR, XENTRY, WIS
I have read pretty much everything about getting my own diagnostic tools to do my own programming on my 2003 SL55.
I am still very confused and there is so many competing products, I hope someone could just give me a straight answer.
Long story short, I got the strutmaster coil conversion done, it is pretty good btw, if people wanna know how I think, just ask me.
I really didn't want to use the bypass module, but the shop didn't know how to program the ABC error away, so I am looking to just invest a system where it has the ability to program the ABC out, have WIS so that I can look at repair information when I need help on fixing my own car, and whatever sweet extra functions there is.
I want a VMWARE system rather than a full on Dell laptop because I am very good at computers and virtualization ability.
Please, please, please, someone just point me to one that has worked before or you are fairly certain is what I am looking for.
I don't care if it's in Chinese because I can read it perfectly too.
Thank a million!
J
I just went on your website and just saw this: http://www3.sympatico.ca/gmacgruer/S...ilOversMin.pdf
That is some good stuff, I wished I had seen it before I made the conversion to the Strutmaster kit.
Not to argue with you, but since on your guide, you had said that you have trouble getting owner's review about the conversions, here is the opinion.
"Someone who isn't me; SWIM"
, was driving very aggressively on the freeway going way past the speed limit and doing "dangerous" maneuvers just to see how the car performs, later up a mountain snake like road. The whole no sway bar thing got SWIM worried initially, but now after the conversion SWIM can say the following: SWIM actually like the car after the conversion better than the stock ABC. The handling is different like one would expect from a coilover. The ride is actually nicer, and the handling is about 95% the same. Body roll is a bit more but it doesn't bother SWIM at all. It bounces or some may call it softer suspension a little more, not to the point of an old cadillac though, or some may also call it floating. Anyway, I went deeper into the world of DAS system and realized the following:
There are mainly two types of DAS system you can buy; 1) MB hardware diagnosis machine + a computer/tablet. or 2) MB Hardware Diagnosis Machine + VMWARE virtualization software. (should work on majority windows computers)
For MB hardware, there is C3, C4, & C5. I think C5 is the newest and probably should get that because C3 isn't supported by newest software updates anymore from MB.
For a computer/tablet, the preferred is a Dell D630 and some other ones too, mainly refurbished computers I noticed. But I assume the seller would have a working thing out of the box, so it might be worth the money if you are very computer shy. The tablet is an awesome looking EVG7 touch screen and makes you look like a professional MB tech, it is more expensive.
For the computer aspect, I believe there are several things going on (I hope someone can just correct me if I am wrong):
1) The software is most likely a pirated system that works.
2) The software is locked in and activated per hard drive so the sellers insist on selling the entire package with the computer so that car repair techs aren't frustrated with the world of activating pirated software through key generators and cracks or what not.
3) The software itself is available as a torrent or some sort on sites like MHH Auto. It should be a huge file to download and if you have no idea what I said in point 2, you should never bother going the VMWARE route at all.
Now, I haven't pull the trigger for anything yet because I am still researching, so the points above are all theoretical understanding.
I am very good with computers so I am spending my time learning all of this for an intellectual purpose. Another reason is I want to save a few bucks as I don't trust refurbished hardwares from questionable Chinese sources.
If anyone has a VMWARE rig, please let me know how slow is it exactly?
At this point, any deep level insights is greatly appreciated!
Thanks,
J
Thanks for the review of the coil-over driving feel, etc.
Could you let me know what are the heights from ground, of front and rear inner fender/arch upper edges?
I want to do some form of coil-over conversion and have been scouring the web for a couple of years now, collecting together as much info as possible, before moving forward. I have difficulty getting reviews.
Keep us informed how you get on with DAS, etc.
I recall being able to use SDS / DAS many years ago to correct values in the KI and EIS but have noticed that in the 2013, 5-2015, and 3-2017 versions the developer options no longer cover this fully. (I'll check to see if I still have an image of 2003 or earlier software.)
If you try to get a version much earlier than 03 the software might not even cover your car since the car may not have existed yet in the software.
Are you saying that the guide above to code out the ABC might not be available in the latest software? If so, that would be a huge bummer for me....... can someone please check for me with their newer STAR system?
Im very close to buying a system with the new 2017 version. I would find it too frustrating if I can not do it.....
Thanks,
J
Note that as of 2002, SDS / DAS still had recent updates available for W140-series onboard controllers. This is known because at that time I had a 1996 S600 in Beijing and a 1999 S600 here in NYC. Both had eligible updates for the klimaanlage system and I applied them accordingly (admittedly there was not much difference in operation).
J
Just measure from ground beside wheel going past the wheel centreline until it reaches just under the fender lip/edge. Another option, is to measure to wheel centre (as image shows).
My ABC front (on lowest), from ground to fender lip measures 27" while my rear is 27.5".
Thanks, Geo.
I am also looking into seeing what @pmercury is using for his VM setup, he seems to be quite the pro. I am hesitant to pay for any of the Chinese stuff because I know there will be no/limited support
Here is my setup for my virtual host
Laptop: Lenovo T450
Processor: I7-5600U
RAM: 2x16Gb Micron DDR3 1600mhz (32gb total)
HDD: 1TB SSD
VMware Workstation 15.5 Pro
I use no VM
My system is a unique and acclaimed 2020 build https://mybestdealers.com
"The best or nothing"
It's always better to read what people that have had them all think of it:
https://mbworld.org/forums/sl55-amg-...ml#post8101695
reviews here
enjoy
