SL55/63/65/R230 AMG: 76mm Supercharger Pulleys for 55k engines
50- 55 rear wheel hp and torque gains
Skip over the 83, and go directly to the 76!
Only $765!
We use heavy duty springs, which make our pulleys much more durable than the other pulleys on the market
Check them out at THIS LINK
It’s a 4th car that I just wanted to have and will get driven maybe 2-3k miles per year. So my question is does the 76mm SC pulley require all the cooling mods In order to safely add power or can I do just the pulley for my use case of limited driving and the occasional highway pull or roll race?
Yes we'd recommend adding cooling to your set up if you upgrade to a 76mm. The best solution would be one of our split cooling kits >> available here
Therefore, if you want full power all the time in warm climates, a KC is a must. Split coolling systems alone will not get you there, I know, I have both.
