SL55/63/65/R230 AMG: Sticky console buttons?
Personally, I have found carnuba car wax works well in removing the deteriorating ‘soft touch’ factory coating on the buttons. It leaves just the smooth plastic piece. The icons are molded into the button itself and stay intact.
But - I now have a extra set of buttons if I ever need to replace
I tried cleaning the buttons with alcohol and goo off. It took the sticky off but it took off all of the black. Now the buttons are white. Does anyone know the part numbers for the three buttons and how to remove and replace them. Thanks in advance for any help.
I'll look to find the instructions and post here when found. The parts dealer should be able to print those up for you.
The part number was A2308200010 and then was replaced by part number A2308213451 . Keep in mind that these came in various colors, so you want to use the color code that is correct for your car. I attached a copy of the R and R. the center speaker grill comes out first with careful use of a plastic pry tool.
hope that helps,
Chris
EDIT, I don't know why I did not see that norcalsl55 had already answered this .... curse my semi-functional browser
my $.02
Chris
I installed the new switch today. It look like new even though it is 13 years old. Thanks again for all th help.
