SL55/63/65/R230 AMG: 09 SL63 head bolts
Old Sep 4, 2018 | 01:01 PM
flippir's Avatar
2009 SL63 AMG
09 SL63 head bolts
Has anyone else had a failure of head bolts on an '09 SL63? Dealer says there is an LI document on this. Some engines noted to have bolts break resulting in coolant entering combustion chamber. Mine drank the coolant reserve tank dry. If this is a known defect in the bolts, why isn't it a manufacturer's defect?
Old Sep 4, 2018 | 01:57 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Lots of reported failures on various 63 AMG vehicles. Yes, is a defect.
Old Sep 5, 2018 | 06:54 PM
K507's Avatar
2018 GLC 63 AMG Coupe
Most M156 engines (6.2L) between 09-11 are affected by head bolt issues...best to research 'known issues' prior to purchasing
Old Sep 5, 2018 | 10:31 PM
ItalianJoe1's Avatar
2003 CL 600
There's no extra warranty. Pay to have it repaired with the updated bolts. Well known on the early 156 engines, regardless of vehicle.
Old Oct 21, 2020 | 05:47 PM
glhansenjr's Avatar
2009 SL 63 | 2009 C63
Does anybody have the VIN range for affected vehicles/years?
Old Oct 21, 2020 | 09:23 PM
HLG600's Avatar
2009 SL63 AMG
https://mbworld.org/forums/c63-amg-w...y-2011s-2.html
More important than the VIN is the affected range of Engine Numbers
If original, your '09 C63's head bolts fall into that range.
Old Oct 22, 2020 | 08:01 PM
bruceeboy's Avatar
2013 F12
Pretty certain all '09s have the defective head bolts, but if you want to check...
Step #1 Go to this website and plug in your VIN to get your build data & look for your engine number > https://carinfo.kiev.ua/cars/vin/mercedes/vin_check
Step #2 Refer to the attached technical service bulletin to see if your engine number falls within the affected range.
I have an '11 SL63 and unfortunately, it appears mine falls within that range. 45,000 mi so far and no issues, but I'm probably going to sell the car and from my observations on BAT, the difference in value for a car with the head bolts replaced if all else is in good order appears to be substantial, so I'm thinking I may replace mine even though no signs of trouble yet. I asked for a cost estimate at the Tucson MB dealer yesterday and they were dumbfounded as to why I'd want to do that, so finding a competent shop may be the biggest challenge.
BTW, there was a class-action lawsuit, however, as you can guess the court favored the big guy > https://www.jacobregarlaw.com/blog/2...on-for-the-m1/
Old Nov 3, 2020 | 03:08 AM
glhansenjr's Avatar
Dang. This really should be covered by MB.
Old Nov 23, 2021 | 04:22 PM
djborden's Avatar
SL63
Thank you very much, that is greatly appreciated !!
Is there any data on what percentage of cars are affected?
Old Nov 23, 2021 | 04:24 PM
glhansenjr's Avatar
Do it yourself
dealer wants $9,200
Independent shop $4,500
DIY $850
I've done a C63 and SL63
