SL55/63/65/R230 AMG: NGK SPARK PLUGS HELP
Bosch is FR6MPP332 if this helps
It states on those plugs that they are pre-gapped, but it also states - must adjust gap - 1.1mm = .044 in.
The plugs that came out of the car are NGK IFR6Q-G. He said these are listed on his MB parts list for 2007 and up SL55’s. Mine is a 2006 with production date of 12-2005! He told me not to install the current plugs I have or it can cause seriois damage!
https://mbworld.org/forums/sl55-amg-...-sl55-amg.html
In researching the NGK LFR6AIX-11 that you purchased for replacements, The IX stands for "fine wire Iridium center electrode" and the 11 stand for the plug gap (1.1mm).
Also, even though these plugs may come pre-gapped from the spark plug manufacture, ask the dealer for the gap spec for your car. The plug purchased may be different than what is recommended by MB. (NGK recommends .032 on the LFR6AIX-11 for your car).
https://www.ngk.com/learning-center/...i-gap-my-plugs
https://www.ngk.com/learning-center/...g-instructions
https://mbworld.org/forums/c-class-w...um-3588-a.html
I'm heading over there now and bringing the new NGK plug to verify gap and thread length is correct.Now I have this other concern! I have some mods from Renntech, ECU upgrade, carbon intake, pulley and resonator delete. The tune was with the old "incorrect" plugs. Will the new correct NGK's drastically effect my mods now? I'll have to contact Renntech on Monday I guess. Also my car had the P30 package which increases the top speed to 186 MPH - I doubt different plugs were needed for this factory option right? Thanks again for you help.
I confirmed after some much needed sleep you are correct on these plugs being for an SL65!
While the LFR6AIX-11 plug you purchased will work with gap adjustment, NGK recommends to not modify the plug gap by more than .008 in either direction.
Yes, gaps have been corrected to spec. I think they were at .040 out of the box. Parts guy re-gapped then for me at the counter. What service! I didn’t even buy them from him. 👍
Now I just have to wait for my twisted back muscles to heal. I’m 6 feet tall and may jack the car up before attempting the job again.
My non car friend asked me "Isn't a spark all the engine needs to work? How does an engine know the type of plug you stick in it?"
I can see his point but, again in my particular issue, having the wrong plugs and gap didn't have any ill effects (except maybe for a 10 mpg average in spirited & daily driving) I'm sure my case is unique and other factors may be involved.
Thank you again for all your help! I owe you one for this. BTW, I’m now averaging about 14 mpg compared to 9 mpg! With the new found power, I suspect I’ll dip back down to single digits on “spirited” drives. Mileage is something I don’t care about in this type of car but, having correct plugs really do make a difference guys. Check your plugs if you haven’t since purchasing your SL55.
