SL55/63/65/R230 AMG: Top won't go down and tilt/telescopic steering wheel
I'm pretty sure it used to work immediately before but just curious if this is a battery thing like it has to get some charge in it first before these items will operate?
I only drive my car maybe once a week so maybe the battery in the rear is low?
Looks like this anomaly happens the very first time it starts for the day as the top opened after I got to work this morning too, but it wouldn't open in my driveway after 1st starting it.
I noticed it displayed something in the dash pod like Not Operational, Check your Owners Manual when I pulled up the button to open the top this morning.
This happened last Sunday too, first thing in the morning but on the way home from tennis the top worked fine again.
I could use the electric tilt/telescopic steering wheel at lunch right after starting it too.
Strange?
I just bought a battery tender and need to investigate the best place to connect it in.
I bought a good battery charger (Schumacher) that I used to fully charge the batteries. Over time they got worse so I had them replaced. Yours should be fine when they are fully recharged.
If I connect it to the consumer battery in the trunk will it also charge the starting battery in the front or do I need 2 ctek tenders?
A good feature of this system is the car will always start. If the trunk battery is completely dead the metal key opens the door. Then put the regular key in the ignition and the car will start off the front battery. It might take a few seconds for the starter to respond.
If the trunk battery discharges below about 60% the CTek will not recharge it, the protection circuitry in the CTek will show an error signal. That is why I bought the Schumacher charger. My old battery would discharge down to 20%, the charger would restore it to 70% in 10 minutes so the car would work normally. I also used it to start some friends cars with dead batteries. After I replaced both batteries I have no needs for either device. If the SL sits for 3 weeks it will start fine but it takes about an hour of run time to fully recharge the trunk battery.
I bought a Ctek charger-maintainer so let's see how that works once I get it all hooked up.
However for long term storage, you need one on the starter battery (under hood) as well. Mines mostly stored all winter so my starter gets a tender too.
