SL55/63/65/R230 AMG: Help Please!! SL55 stuck in park. ESP / Battery / SRS Warnings
_
- I have a 2006 SL55 AMG, 67K miles. The vehicle has a new aux battery and new rear battery, as of this year.
- Out of nowhere a Visit Workshop battery warning came up a few days ago. I drove the car a short distance home immediately.
- The next day I started the car to receive several warnings, ESP, Brakes, Battery, visit workshop.
- The following day the car would not even unlock, the battery was completely dead even though I hadn't even moved the vehicle.
- Today I went to replace the rear battery, since the aux battery showed correct voltage. I used a jump box to start the vehicle and drive a couple miles to the auto store.
- I bought and installed the brand new battery (in the auto store parking lot). Once installed and started, my car wouldn't even shift out of park--the shifter is stuck in park. I left the car idling hoping it would somehow self correct only to find the car began to overheat (after 15min of idling) and coolant started overflowing. All the errors are still showing--SRS, Brake, ESP, battery, visit workshop.
- I tried to find a shift override (so I could shift out of park) under the shift boot only to find the R230 doesn't have one? Correct me if I'm wrong about that, but I looked all over. So now I can't even override to get my car a short distance back home.
- It seems my only option now is to have my car towed?
I'm beyond frustration and out of ideas. Any help or suggestions would be GREATLY appreciated. Thanks so much.
https://www.pressertech.com/blog/fre...es-ecm-repair/
Do you have at least a iCarsoft MB II( ) to at least plug in and see what codes are being thrown?
You might get lucky and just a few Relays or something got knocked out and with multiple relays being dead it could be causing the ECM to act crazy. But this really sounds like the ECM got fried.
You may want to repost this in the W211 E55 forum. Your going to get a lot more responses and a lot of the guys that hang out over there are very educated on these platforms.
Do you have at least a iCarsoft MB II( https://www.amazon.com/dp/B074224KTH...3920290_dpLink ) to at least plug in and see what codes are being thrown?
I took you advice and just tried posting in the W211 forum. I hope I have better luck there. Thanks for trying to help me out.
Time is running out for me. It kills me that I can't find anyone in any forum that had the same events happen to them. I feel alone on this one. And why did my car not turn the fan on to prevent overheating? It's an electrical nightmare.
- What's with the sudden battery warning when the aux and rear batteries are recently replaced (as of this year)?
- Why did the battery eventually completely die even though I took the car straight home and only started it one more time?
- Why is my car now overheating even when idling, it must be related to the Battery / Brake / ESP error? I've read people claiming after the battery warning their cars have also overheated
- What causes the car to suddenly not shift out of park? Even with the previous warnings it was shifting fine. Only upon installing a brand new rear battery has the car decided it won't let me shift?
- Is there any chance it's the alternator? Brake switch? Voltage regulator? Fried electrical?
- Two things make my situation different than the more common things I've read about:
- (1) neither of my batteries are old and need replacement, and
- (2) the shifter being stuck in park is so random--the shifter stuck problem typically only occurs when the plastic piece underneath breaks, I'm 99.9% that's not what's happening here.
Thanks all, for any suggestions, theories, guesses you can offer!
With that you could at least probably see if the ECM is even reading and then from there see what codes its throwing. Otherwise its just throwing darts at a board here.
Like I said before with this many issues going on it has to be something in the electrical system causing it all to fail. It could be as simple as the SAM system just happened to fried. Do you smell a chemically smelling smell in the trunk? At least check that out as you can visually see it most of the time its shot. https://mbworld.org/forums/w211-amg/...unk-oh-my.html
I'm not sure what the MB alternators will max out at when revved but anything over 15 volts is to high so if he diagnosis the alternator putting 17 volts out my guess is the voltage regulator on the alternator is shot. So replace the alternator to start with and see what happens.
