SL55/63/65/R230 AMG: Anyone have experience with Torque Pro app? AFR?
The car seems to run much better / more responsive when the outside temp is cooler. In the heat, it seems to run like a slug. I did a quick 0-60 test using the app and it was terrible... like 7.9 seconds.
Thanks,
Matt
pretty sure I saw some instructions in the forums regarding replacing the IC pump. I’ll give an update when replaced.
One quick question regarding the new pumps connector. I’ve read conflicting info whether it is plug and play or whether I need an adapter?
Thanks.
You can check the fuse for good measure but it's probably the pump.
Also AFR's can really only be monitored with a dual wideband sensor connected to a data logger or display to see any kind of accuracy. Also AFR's usually don't get messed up unless you load a tune or have some other major issues going on.
A second thing I noticed, was the new pump’s vacuum hose connector does not have hole in it. Not sure if that’s by design or if the unit I have is defective. The original vacuum connector has a hole in the middle. Anyone know what’s up with the new pump? Vacuum hose may as well be disconnected.
***** edit **** All photos I’ve viewed show the vacuum connector just as my unit is... no hole. I guess they did away with it.
Thanks,
matt
Thanks for everyone's help!
Thanks,
matt
https://mbworld.org/forums/sl55-amg-...ml#post7774121
Thanks,
Matt
