SL55/63/65/R230 AMG: Help
Old Sep 8, 2019 | 12:24 PM
Madara's Avatar
SL55 AMG 05
Unhappy Help
Hey my supercharger pully wasn't engaging and I replace the pully itself and still doesn't
anyone have any idea why? I have a video of it.
05 SL55 AMG.
Old Sep 10, 2019 | 12:20 PM
Nor Cal SL55's Avatar
2012 E63 AMG
There is a magnet that triggers the engagement of the pulley. Yours may be bad? Bad connection?
Old Sep 10, 2019 | 12:26 PM
Madara's Avatar
SL55 AMG 05
How do I check this? any ideas
Old Sep 10, 2019 | 01:41 PM
2012 E63 AMG
Check out these threads.
Hope this helps
https://mbworld.org/forums/w211-amg/...es-engage.html
https://mbworld.org/forums/w211-amg/...removal-2.html
Old Sep 10, 2019 | 02:03 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Good stuff here. Use the "translate this page" button on your browser address bar to better understand. Helhans website is a great private website and I find it to be an invaluable source of information.
You're wanting section 3.2 Connections Magnetic Coupling
http://hehlhans.de/motorg55-7.htm
If you have STAR/DAS/Xentry you can check the magnetic coupler under the Motor Electronics section. It will be either controls or actuations; I don't recall at the moment.
Old Sep 10, 2019 | 04:34 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
If you have STAR the on/off may be reversed it was on mine , activating the magnet off actually turned it on/energizing it FYI
Old Sep 10, 2019 | 04:51 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
This video is meaningless, since on no account will the supercharger engage on a stationary vehicle.
Presuming the compressor is not engaging, then at the engine ECU I would measure the voltage on its control signal using a multimeter.
Old Sep 11, 2019 | 10:03 AM
Madara's Avatar
SL55 AMG 05
I'll try to check with STAR and see because im keep losing and power and it comes back, had the problem before I replace with a new pully still don't know what causes this
