SL55/63/65/R230 AMG: Head Gasket Oil Leak??
Old Jun 26, 2021 | 06:40 PM
MK19's Avatar
Just sold my '11 Porsche TurboS cab for an '03 SL55!
I've been chasing a motor oil leak around the rear of the left cylinder bank. I jumped to the conclusion that it was the valve cover gasket, but when I got the covers off, they looked pretty dry. New gaskets anyway, but the leak is still there. After cleaning and driving and cleaning and driving it sure looks like its the head gasket that appears to have some RTV like black rubber sealant around the lower edge. I've checked and rechecked the breather hoses under and around the throttle body and they're dry too. I don't see any other potential source up in that area.
Anyone experience this leak? Are there other leak sources I should be looking at? Seems a bit odd on a 73k mile car, but it is 18 years old...…..
Thanks for any help.
Old Jun 28, 2021 | 10:30 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
There is a path (channel) for oil and fluids to escape from the valley under the supercharger that ends up at the back of the left head. The passage is cleverly cast into the back of the block under the rear-main-seal retainer/plate and exits about where the starter would be mounted (IF the starter were mounted on the left instead of right).
See pic
hope that helps,
Chris
Old Jun 28, 2021 | 10:43 AM
MK19's Avatar
Chris…….YES, very helpful.
Can you tell me the source of this leak from under the Supercharger?
What will I need to remove and what seals/gaskets/hoses etc. will I need to reseal and reassemble things?
Thanks a lot.
MK19
Old Jun 28, 2021 | 10:54 AM
Thanks a lot.
MK19
I would begin by confirming that this is the source (the drain hole). I have never had a leak here, myself. And, it is not immediately obvious to me how oil would leak past a gasket and make its way through here.
Supercharge front-case-oil could I suppose (but doubt there would be much).
Coolant the from Intercooler and/or supply pipes could make its way here.
A really bad valve cover leak perhaps (but you have ruled that out already).
And, I guess you could have a bad seal on the retainer-plate (of the rear-main seal) ... but that seems like a long-shot (and requires the trans be separated from the engine to get at ... so lets hope not)
Hopefully someone else will have some experience that they can share that would shed some light here.
but first, do confirm that this "drain" is the source of your drip
Chris
Old Jun 28, 2021 | 12:36 PM
MK19's Avatar
Thanks for the picture and all of your inputs here Chris.....and yes, hoping for further insights from others too.
I'm now wondering how I'll confirm (or not) the leakage you have pointed to. In the photo, am I looking at the rear of the main (crank) shaft with the motor removed? Or is that the front of the blower with the clutch removed?
I'm pretty sure it's not the main shaft seal as I can inspect the lower/inside of the bell housing and it's pretty dry.
I am seeing only motor oil, no antifreeze. And no oil in the coolant tank either.
It's a reasonably sizable leak that can result in a 6" diameter oil spot after a drive and cool down.
I'm guessing that the main oiling system also lubricates the blower......correct??
Best, Mike
Old Jun 28, 2021 | 01:15 PM
Best, Mike
I showed you a picture of the rear face of the motor because that makes it easy to point out where the "drain" is. What you will want to do is to look for (and then look at) where the lower hole (that I indicated with a red circle) comes forward (exits the block). It should be a hole close to 10mm in diameter and you should find this near where the starter motor WOULD BE IF it were on the left side of the engine. You may be able to see it with a flashlight and a mirror, but if you have a borescope it would be easier to see. I have several borescopes, but the least expensive one I just bought recently may be my favorite.
Amazon Amazon
the blower is not connected to the main oiling system, but instead has a smallish gearbox in the front that holds a small amount of fluid (probably not the source of your re-occurring spot).
HTH,
Chris
Old Jun 28, 2021 | 02:00 PM
MK19's Avatar
Great, thanks Chris.
Will let you know what I find.
MK
Old Jul 2, 2021 | 06:32 PM
MK19's Avatar
Embarrassing!!
I never found the hole/vent that you pointed out latemodel21, I probably needed a mirror that I didn't have at hand but I did find the source of my main oil leak.
Looking around up under the head/valve I sensed that maybe the newly replaced valve cover gasket could be to blame even though I had previously had the coils out and could run my fingers all around the suspect rear/lower part of the gasket and they came up more or less dead dry.
But I decided to pull the valve cover in case I didn't get a part of the gasket in the groove. Well, the gasket was in the groove nicely and looked great. But as I was trying to sight down behind the head for any clue, I spotted the mounting tab for a vacuum line that is intended to be attached at the upper, rear most valve cover bolt. It was sitting right on the gasket surface of the head. You can probably guess the rest. I closely reexamined the valve cover gasket in that location and found a matching impression. Yep, rookie move, I'd not noticed this mounting tab and I slid the valve cover right back in there and right on top of this mounting bracket. It's surprising that it sealed as well as it did. All better now except for a very minor leak more forward on the engine that I'll go after next.
The other observation here is that these Syn oils tend to be dry in a film state as was the case here......so it can be hard to detect the leak source. I guess that's why some shops use dye/black lights.
Thanks all for the help and especially Chris. Cheers!!
Old Jul 2, 2021 | 08:44 PM
Glad that it turned out to be an easy fix, and glad that you posted a detailed follow up (too many people seem to never come back and write the outcome/solution).
Cheers and happy holidays!
Chris
