SL55/63/65/R230 AMG: First hand trickle charger experience...
I did not drive my 2004 SL55 AMG regularly for the first few years of ownership and sometimes got the consumer battery (rear trunk battery) light which goes out after a few minutes of driving. I started using two battery tenders on the car about 4 years ago and this solved my issues.
However, recently my starter battery (front, underhood battery) failed (probably due to age) and I jumpstarted the car twice (without disconnection the rear battery per the owners manual...I did not see that section-see below). I could not get the battery light to go out and my independent M-B shop found an electrically overstressed (burn smell, soot, etc...THIS CAN BE CATASTROPHIC) Load Separator Module. My independent said to not put a trickle charger on the car...just drive it more often.
Sure enough, life/weather got in the way and I did not drive the car for a month...and the consumer battery light came on (on start). Again, it goes out after 30 seconds BUT I know that depleting a battery like that reduces its life.
Do you think this is the secret:
https://mbworld.org/forums/sl55-amg-...or-module.html
https://mbworld.org/forums/sl-class-...ol-module.html
I have learned a few things about changing the rear battery (at least on my 2004 SL55 with keyless go).
Do not have the key fob anywhere near the car when you change the battery as it may (will) reinitialize and cause the key fob to be in-op.
Top Post Battery Disconnect Switch, Ampper Battery Master Switch Isolator for Power Disconnect Cut Off
Top Post Battery Disconnect Switch, Ampper Battery Master Switch Isolator for Power Disconnect Cut Off https://www.amazon.com/dp/B07JYYXJH7...SX242312WRVG1Q
1) Doesn't separating the battery from the circuit (while trickle charging) lose your radio preselects, clock, etc...?
2) I do not understand: "I added a plexiglass spacer to keep the “Off” condition."
Tom
