SL55/63/65/R230 AMG: Solution for SL65 Launch "Bog-down"
Old Feb 20, 2005 | 11:27 PM
thearle's Avatar
My wife and I both drive a "65" - CL for her and SL for me. I don't know other "65" owners experience this, but here's my story.
The SL65 kills or bogs-down the engine during a hard launch from zero - an interesting but a very annoying occurence, especially when the engine spools up to drive the turbos, ready to deliver the power/torque.
The computer, I am told, takes over the car.
I had a shop remap the ECU settings and now the car's launch can be somewhat driver controlled - so much better than stock setting.
Now its just a matter of getting the tires to grip better.
Old Feb 21, 2005 | 01:01 AM
treynor's Avatar
SL65, 911
Odd, I never experienced the behavior you describe. My SL launched cleanly from a dig when it was stock. Still does...
Old Feb 21, 2005 | 08:10 PM
Schiznick's Avatar
SL65, E55T, Pending S65
I will second that, very odd. I have never had that problem. Traction is another story!
Exactly what "shop" did you let re-tune your ECU?
Schiz
Old Feb 21, 2005 | 09:57 PM
RonG's Avatar
SL65, 05' & Ford GT, 06'
Let me third that. It's the traction baby, not the launch.
Old Feb 21, 2005 | 10:58 PM
vrus's Avatar
2003 E55 AMG
I think the "bog" you are describing is most likely the ASR putting the brakes on to try to control traction.
Old Feb 22, 2005 | 01:01 AM
thearle's Avatar
I drive my cars hard. I do not believe it is ESP/ASR.
ESP/ASR occurence is a feeling of locking brakes while the engine RPM still holds high.
"Bog-down" to me is a different phenomenon... more like engine stalling or choking - RPM or engine speed is heavily reduced. Your tach needle goes down to 1500 rpm.
Try a medium hard launch, spool the engine to about 2500 rpm then release the brakes while depressing the accelerator deeper in a gradual, linear fashion. Once you reach 4000 rpm (that is, with the ESP off and your tires are slipping), your engine will stall and reduce RPM to about 1500.
Old Feb 22, 2005 | 06:52 AM
Schiznick's Avatar
Tried it this morning on the way to the gym.
My car does not reduce RPM, the tires are still spinning in first and if you are manually shifting in drive it will sometime short shift.
Schiz
Old Feb 22, 2005 | 08:04 AM
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
very weird?
