Performance Pack on Facelift Cars?
412 - is the optional Magic Sky
486 - is the optional AMG 2 Stage Performance Suspension
23P - is a sub-code within code 997 / Driver Assistance Package
Good Luck, Steve
Most of the options and definitive if you read the decoder and I think the PP is all that was before but standard now on the 577hp cars.
greater agility and high cornering speeds, the AMG SL models have more negative camber all round and fully
revised, substantially stiffer elastokinematics. At the touch of a button, the Performance suspension (optional
for AMG SL63, standard on AMG SL65) offers an emphatically sporty characteristic with reduced roll angles
and taut body damping at the touch of a button ("Sport") or a more comfort-oriented set-up for a high level of
comfort on longer journeys ("Comfort").
There is definitely parts differences. Perhaps software as well. In any case it makes it a track suspension with the 486. If you google Mercedes sl63 option 486 you will find plenty of information.
Below is the excerpt from the MB own brochure on 2018 SL:
Competitive spirit, superlative specs.
Based on Active Body Control, the AMG Performance Suspension teams advanced electronics and hydraulics to actively counteract pitch, dive and roll with millisecond-quick response and multiple modes. An optional setup adds two-stage damping that’s also 30% firmer damping in Sport mode. Silver or optional red calipers grasp the 15.4" front/14.2" rear composite brakes. Even larger yet lighter Ceramic Composite brakes are an option proven in racing.
In the second sentence MB implies that AMG performance suspension is fitted in every AMG SL. In the third they talk about optional two stage dumping that is 30% more firm in the sport mode. From other posts we know that there are both the software and the hardware differences between the cars fitted and not with this option. The language is gone from the 2019 brochure. The way I read it, sometime in 2018 the “option” became part of the standard equipment but MB continued to separately charge for it and all there is is a 30% firmer dampers when set in sport mode but not so in comfort mode. This would explain why MB has been so vague with their answers related to this matter. I have not seen a single sticker on Autotrader that did not have this option included in the build on 2019 SL63s and I have seen many.
and different program somewhere in the eng, trans sport program. Alot of MB programming is a mystery or secret
