SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: PSE, Central Locking & Alarm problems. HELP!
Old Apr 25, 2005 | 03:19 PM
Pigzmickey's Avatar
1998 SL 600 ///AMG. 1997 SL 320. 1999 SLK 230K. 2001 BMW R850.
I recently changed the pump on my wife's SLK 230K (1999), it was corroded. We found the alarm / central locking & the window drop (on door opening) wasn't working anymore, all these things started happening which is when I noticed the pump problem. I replaced the pump but the only thing that changed is that I can now use the central locking from the dash button. Do I need to get the new pump coded to the car, could the pump fault take out the alarm also?
I'm completely confused now, I thought the new pump would rectify all the problems...
Please help me!
Old Apr 25, 2005 | 09:00 PM
mercedestech1's Avatar
To answer your question-Yes the PSE needs to be coded to the vehicle. Also make sure the plugs that go to the PSE are cleaned of corrosion too.
Old Apr 26, 2005 | 04:18 AM
Pigzmickey's Avatar
Cheers!
Old Apr 26, 2005 | 12:35 PM
gary350's Avatar
SLK230K & SLK350
I am having a new PSE fitted to my 230K today, asked the dealer if he could turn it upside down as in later models, they would try but cables may be to short. He will put it in a plastic bag, technolgy is a wonderful thing.
gary
Old Apr 27, 2005 | 06:32 AM
Pigzmickey's Avatar
gary
Ain't it just!
Old Apr 27, 2005 | 09:53 AM
gary350's Avatar
SLK230K & SLK350
The bill came to £600 for just the new PSE and fitting, plastic bag was free, great for something that should have been a warranty and recall issue, it is a major fire safety problem how have they got away with it, I would like to know how many cars have had the same problem 1000,s I would imagine. I have had a look to see if my SLK350 has a similar system, can,t find the PSE lets hope the water can,t either.
gary
Old Apr 28, 2005 | 03:16 AM
Pigzmickey's Avatar
Did they code it? What problems did your faulty PSE cause, alarm, windows, etc....
Ours has stopped so much from working, it seems like a conspiracy!
Old Apr 28, 2005 | 03:46 AM
gary350's Avatar
SLK230K & SLK350
My son drives the car more than I do but here goes
The coding I know that if the PSE ordered is the correct one (there are many types) then it is already coded if its not they have to recode the system, having paid £100 for fitting 5min job (the PSE is £504) I assume they recoded the faults were locks, alarm, some lights and the centre compartment locked, oh and it floored the battery we had to buy a new one. Still not happy the car has less than 20K on it.
gary
Old Apr 28, 2005 | 05:50 PM
Pigzmickey's Avatar
Thumbs up
I've just disconnected & then reconnected the PSE, I also changed the key fob batteries & recoded the key to the car. Now it all works again. At last...
Oh, and I did the plastic bag trick too. Like you said, it's a pretty poor affair though. Your PSE seems expensive, I paid £304 from Cruickshanks in Bristol (but I fitted it myself).
Old Apr 29, 2005 | 12:13 AM
bazzle's Avatar
How did you recode the key?
Bazzle
Old Apr 29, 2005 | 04:38 AM
gary350's Avatar
SLK230K & SLK350
My son took the car to a MB dealer in Swindon, if thats the correct price £304 I will challenge it, thanks for the info. My son asked the dealer to fit it upside down like later models and the maker Hella advise, they could not cables etc were too short.
gary
Old Apr 29, 2005 | 07:32 AM
Pigzmickey's Avatar
If you want a copy of my invoice, just send me your Email address & I'll send it to you.
Old Apr 29, 2005 | 10:24 AM
gary350's Avatar
SLK230K & SLK350
pigzmickey, your right just called my son the bill came to £504 the PSE was 304 fitting 120 (cant believe that it takes about 3 mins to fit the 2 connectors and the air tubes, robbery) that comes to 496 so the plastic bag must have cost £9, oh the bill had been slightly upped because he was getting his mum to foot the bill cunning little B+++++d.
He also said everthing worked apart from the auto locking as you drive away the dealer said just press the C/L switch beside the radio for 10 seconds that does it.
gary - nice to talk to you
I have set my alarm to check the PSE everytime it rains or the car gets washed - once bitten twice shy.
pigzmickey, you, me and bazzle are like something from The Hitchhikers Guide to the Galaxy we keep meeting on different forums.
Old Apr 30, 2005 | 11:20 AM
Pigzmickey's Avatar
"I have set my alarm to check the PSE everytime it rains or the car gets washed - once bitten twice shy"
How? I've never heard of this before...
Old Apr 30, 2005 | 12:11 PM
gary350's Avatar
SLK230K & SLK350
Its an alarm fitted to the top of my head something like a rain sensor, oh number one son said the extra 100 was for a new battery so I take it all back.
gary
Old May 3, 2005 | 09:19 PM
bazzle's Avatar
pigzmickey, you, me and bazzle are like something from The Hitchhikers Guide to the Galaxy we keep meeting on different forums.[/QUOTE]
Australia, Whales and ?????
Bazzle
Old May 4, 2005 | 03:45 AM
lonny's Avatar
Guys,
Where is this sensor - I get the impression it is in the wheel well but I have never seen it - can you give me an idea wher eit is so I can check mine??
Thanks,
Lonny
Old May 4, 2005 | 12:56 PM
Pigzmickey's Avatar
Bazzle[/QUOTE]
Hows the weather Bazz? I'm hoping to migrate to Adelaide next year, I'd like to bring the V12 beast with me...
