SLK/R170: CD Player?
I'm about to install a OEM CD changer in my 320, I liked the way you installed it, so I'm wondering, did you use the standard MB installation bracket? If not how did you keep it in place?
Thanks.
ALso, does anyone have pictures of the stock CD-changer installation? I think I only have half of the bracket. I have the part up against the plastic panel that covers the roof motor, where the wires come out. Also, when putting the two HU wires in the same plastic clip, does it matter what order they are in?
To save space in the trunk:
Also, since the head unit keys I ordered with the CD-changer didn't get shipped, can someone tell me how to remove the head unit by using a swiss army knife, like the SLK32.com directions say? I never removed a european HU before and have no clue what I need to feel for.
There are two pieces of plastic. The first is the panel that covers the space for the optional telephone unit. It is held in place by the plastic pins. Remove the four pins and it comes right off.
Go ahead and pull this off and take a look. It's a lot clearer to do this than try to understand my poor explanation.
The second piece of plastic is the trunk liner. It is a large piece, but you don't need to remove it. I just cut a hole in it while it was in place. There is already a good portion of a 'hole' (actually a recess open from behind) for the telephone unit. You just expand this existing hole (quite a bit) to get the changer to fit.
Yes, I ran wires from the passenger side. Cut and splice a section in. I removed the back panels and ran the wires through. Not hard.
Follow the directions on slk32.com to remove the head unit with a Swiss army knife. That's exactly the way I did it. It's easy.
