SLK/R170: 99 SLK - Oil Leaking Convertible Top
I took the car to an independent Mercedes repair shop and they said the hydraulic pump was low on fluid. They said they added fluid and they were able to get the top working. When I picked up the car, the top was up, the vent windows were up and closed, and the light was off on the convertible top switch. I just drove the car home without trying the top, because I was afraid that the top would malfunction again and the vent windows would be stuck in the open position. And I didn't have time to mess with it, because I had other commitments.
Today, I had the courage to try the convertible top again. I started up the car and made sure that cover in the trunk was pulled out in position. Rolled down the side windows and pressed the convertible top switch. The side vent windows went down, but I could hear a moaning and groaning in the back of the car. The top just stayed in the closed position and would not go down. Then I started to smell oil. Oil started pouring out of the top headliner area by the passenger side vent window and sun visor.
At this point, the vent windows are again stuck in the open position, the top will not go up or down and the convertible top switch light is always on. The channels on the right side of the convertible top are filled with oil and oil is dripping on the passenger seat and floorboard... Where would be a good place to start to trouble shoot this problem? Thanks...
How mechanically inclined are you? All 5 can be rebuilt and there are seal kits on eBay that are reasonably priced. If you can't rebuilt them yourself, but think you can remove them, there are a number of places that will do the rebuild for you. Where are you located? If you were to go to a dealer, I'm sure it would cost you multiple thousand of dollars. They would replace the cylinders, which is pricey, and the labor rate is steep as well
Tim
As for the fluid tank refill - once fluid is in hand, any precautions as per pressure release valve, etc?
mikepompura@yahoo.com
BTW, If you need to fill the hydraulic fluid there must be a leak in the system somewhere.
One thing about this fluid. It is toxic. Not that healthy to breathe either. I'd be careful driving around inside a closed driver area with that cylinder leaking that fluid.
Also - topping off the pump with fluid: plan on spend at least 30 minutes. It will be the most JOYFUL and PLEASANT experience of your life - never to forget....with you hoping not to have to do it again in your lifetime.
No room to spare in there. Big gorilla hands will not fit. Way too easy to lose the bolt cap if it drops down into the body well area.
Takes 15 minutes trying to screw it back on..fine threads, plus its at a slight angle. You need to begin with hand tightening first. PURE JOY.
I was able to finally get it to begin catching threads by hands about 10-15 minutes..after that I hand screwed it tight. Then used a small tiny ratchet and a TORX (30 I think) to finish.
You must use a syringe and a plastic tube (comes with the O ring kit from ebay) to fill the pump. The space and angle make even that a "nice" job.
Just try not to breathe the stuff or get it in your skin. Its a petro based naptha product with plenty of poison warnings.
