SLK/R171: vibration at 80 mph
Slk350(weekend), Mazda 3s (boosted)
vibration at 80 mph
i just installed some iforged retro's on my uncles slk. 19x 8 (f) 19x 10 (r) .. while going about 80 the car vibrates a lot. Does anyone else have this problem or know whats causing this problem? On the rear are nitto 265/30/19. Let me know guys. Thanks and happy T day.
it feels like its from the back. the spacers, are they plastic that go between the rim and hub? if yes, then i got them, but the guy that sold them to me said i dont need it unless my brakes dont clear.
'06 slk55
How would no-spacer cause vibration issues? If someone uses a generic spacer that is not properly aligned, that would cause vibration issues. I dont think not having a spacer would do the same. A spacer more-or-less simply gives you proper clearance of the brake caliper and allows the wheel to be in the center of the wheel well. Right?
It does sound like you just need your tires rebalanced. Take it back to the shop and tell them you plan to drive it fast so they MUST be balanced as best as possible. Maybe the shop had a rookie balancing your set.
yeah they are plastic, but i dont know if they are the actual spacers, but the guy who sold them to me said to use these if my calipers didnt clear but they did, so i didnt use them. I bought the rims with tires mounted, so im going to a performance shop to have them balance the tires tomorrow.
BMW Z3 S/C & 99 Mroadster
Ok its Balancing, which has been stated, however just so you guys know spacers help with clearance, IE rubbing-calipers-etc OR offset-you can break an axle with extreme offsets. There is NO WAY a spacer would cause a vibration at speed.
the plastic things he supplied are probably hubcentric rings, which have absolutely nothign to do with caliper clearence. If the wheels are not hubcentric they will vibrate at various speed intervals.
