SLK/R171: IPod Kit in 2005 SLK
And has anyone actually installed it on their 2005?
I went to look at a used 2005 SLK350 today and the dealer insisted that I would have to buy a new 2006 in order to get the IPod kit.
greetingz,
greetingz,
greetingz,
Also - can it be installed by a dealer/regular store if you're not likely to be in town?
greetingz,
1st, the ipod info cant be display in the navigation command console.
2nd, the small area where it display the info cant scroll, therefore, you cant tell what is the song title if it is long.
3rd, it only displays english (standard ascii alphabet characters.) everyone would assume that it displays whatever the ipod can display, but this is not true.
4th, you cant control the ipod from the navigation command console.
5th, the ipod was design to be put in a destinated area (vertical compartment between the 2 seats) but the cables are not long enough, therefore, it have to stay in the horizontal compartment between the 2 seats.
6th, the aux port does not work after the ipod integration is installled.
now, i am trying to make a splitter to plug the ipod integration and the aux port. so both the ipod integration and aux port can be utilize. however, steve (mbenznl) said this may degrade the sound quality. if this does not work, then i will remove this integration and sell it. i rather use the aux port.
But sound quality is primary and the cable uses unshielded wires.
I wonder if my dealer will take the $299 kit back and refund me? Ouch...
-- Bob
greetingz,
Thanks Steve and Wanda (MBenzNL)...
greetingz,
I notice however that the A, B, C and CLK class cars all use the same iPod adapter kit part number B6 782 4213, which it is said quite clearly works with Audio20, Audio50 and COMMAND.
It occurs to me that using part number B6 782 4213 could be a potential work around for SLK owners who do not have COMMAND. Anyone tried this?
As an unrelated bit of trivia, the E and CLS both use the same adapter (part number B6 782 4202) which like the SLK part requires COMMAND.
I would also be extremely interested if anyone knows if the adapter for the 2007 S Class (W221) part number B6 782 4223 works on cars without COMMAND (as I own such a car).
What I am speculating about is whether those SLK owners without COMMAND and are for reasons of location are unable to get their cars to MBenzNL in California for modification (say for instance people living in Sydney like you or Singapore like me) might be able to use integration kit part number B6 782 4213 instead, since it is stated in Mercedes Benz literature that it works with COMMAND, and also Audio 20 and Audio 50 radios.
It was a pleasure helping you out with your new mod. Enjoy!greetingz,
BigSis
greetingz,
BigSis
greetingz,
greetingz,
BigSis
