SLK/R171: Help W/ My Module..
1) module doesnt light up
2) the security (key) now wont function for lockin and unlocking
3) error message indicating "malfunction, bring to workshop"
4) where to actually put the screw about that "earth" cable??
1. no power to module. check your crimping tool or buy another crimper. it is cheaply made
2. sounds like the canbus is not put back together correctly
3. that error indicates not a good connection as the power goes through the unit and back in. see answer 1
4. put the earth cable (ground) to any metal screw
my light initially did not come on either til i recrimped it but good!
I suggest to borrow a multimeter from a friend, neighbor, work, etc., poke the red wire in the same point you crimp it before and check that you have 12V between this and the ground (metal body of the car). If not, you have to try another red wire. Also there are 2 screws coming from the floor of the car outside the black plastic box with the canbus connectors (the screws might be painted same color as the car). Attach the ground wire to any of these screws and secure it with the nut that came with the module. Also check that you have a short between the nut and the ground.
Did you check this thread?
http://www.benzworld.org/forums/r171...mote-roof.html
Pages 11 to 28 are very helpful and offer lots of pictures.
.. i believe this is where the problem all started... we couldnt find a place where to fasten the earth cable.. but even then, why would my car key lose its power to lock/unlock the car???
Two quick clicks backward on the roof switch, rolls down all windows. Then use the door buttons to roll the front (big) windows back up. This leaves the little back windows down.
1) 15 yards distant from the car and i was able to open up the roof
2) 25 mph was also the maximum speed where i can open the roof.. no complaints
3) the push of a button for a second also worked.. i was really happy w/ this..
4) the auto windows up/down also worked...
BUTTTTTTTTTT.... THE TOP WONT GO UP!!!!!! WAHHHHHHHHHH!!! the only time the top would go up is if when im inside the car and pushin the button.. aside from that, i cant close the top w/ my smart key!!
i know we did everything right... anyone ever ran into this problem before???
Try to press the lock button 3 times, watch as your blinkers blink 3x, then the top will go up, otherwise you might have a defective module?
nyahahahahhaahhahaah.... watta piece of art!!!!
thanx fellasssss!!!! in almost ready to take a picture of may car!! 5 months and i noticed last nite that ive only put 616 miles on that!! am i not using this enuff??
lol
lol
But less than 5 miles per day?!? What a waste…
Get out and enjoy it! NOW!
