SLK/R171: Launch Control: is it safe?
Basically it says:
* Turn off ESP
* Step on the brake
* Put it in Sport, manual, 1st gear
* Step on the accelerator
* Watch the RPMs rise
* Let go of the brake
* Launch!
* Remember to shift up
Is this something I can do safely in my SLK?
In the SLK, what you're doing if you try to perform this, is technically called "brake torqueing". i.e. you apply the brakes to get the car into the correct torque range for maximum push. If I perform this on my AMG, I get quite a bit of tire squeal, the patch just isn't large enough.
The automatic gearbox will technically last just fine. Clutches wear out quick, but the 7G box is made to withstand up to 720nm of continuous torque stress, so a few launch techniques here and there won't do all that much damage, if any.
However, brake torqueing will heat up the brake fluids pretty quickly. This could lead to the brake fluids boiling, leaving you with poor brake action when you need it the most. So if you do try a launch here or there, do it in a place where you won't be left having to do multiple urgent brake stops.
No offense but that's not correct. "brake torqueing" WILL NOT CAUSE your brake fuilds to heat up. For your brake fluuids to heat up your brake Rotor & pads have to be hot (from hard use of the brakes at speed) then the heat will transfer from the rotor to the pad from the pad to the caliper from the caliper to the pistions then to the brake fluid.
So unless your doing a Killer burnout your brake fluid won't heat up.
However you might eventually burnout your torque converter (the automatic tranmissions clutch)
Also i never heard of it being refered to by "brake torqueing" we call it power braking or loading up the T/C (torque converter)
Basically it says:
* Turn off ESP
* Step on the brake
* Launch!
