SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Need to bring 12v cable into armrest.
Old Jan 10, 2008 | 09:54 PM
Cixi's Avatar
SLK 350 AMG Kit - Ex owner of SLK 230K
Question Need to bring 12v cable into armrest.
Do you know where I can get a 12v cable (like from the back of the cigarettes ligher but easier to connect) that will allow me to transport the cable into the armrest?
I have many electrical things inside there so I need to power them while moving.
Hope you can help me.
Old Jan 13, 2008 | 07:35 AM
Limibeans's Avatar
2004 C230K (Looking for new MB)
Few questions:
1) How much current is needed?
This will determine the size of the wire needed. Do not sell yourself short here. Sure, large gauge wire is expensive, but if you plan on charing your cellphone, powering a laptop, coffee grinder, and electric razor all at the same time you will need a heavy gauge wire. Small gauge wire will either cause the wires to melt (and possible cause a fire lol) or your appliances (for the lack of a better word) will fail to function.
2) What will you be powering?
This will determine what "adapters" you will be "plugging" into.
Im thinking you can just hook it like like you would an amp for a stereo. You just need to have a fuse in between the battery and "plug" for safeties sake.
Since you have "a lot" of things you need to plug in, you will definitely want to run its own wire in there.
Old Jan 14, 2008 | 09:37 AM
Cixi's Avatar
1) I already used this system in my SLK R170 with the power from the cigarettes lighter so I think I will have no problems here too I guess.
2) I have a 110 Volt converter 60Watts plus three socket expansion inside the armrest box.
So I can charge 1 phone+1 laptop pc+some other tool
I don't want it visible.
So I don't want any wire go from outside near the comand to inside the central tunnel.
That's why i'm looking for a place where to take the power.
Otherwise I have to unmounth the front of the comand to access the back.
I thought to take some power from the MOST connectors under the passenger feet.
Old Jan 29, 2008 | 10:44 PM
midget fidger's Avatar
E550 Coupe
I installed the SmartTop module last week and got 12V from undernearth the driver side carpet. Check out http://www.mods4cars.com/ for the installation instructions to see where. It was kind of a pain to unclip the plastic box.
Old Jan 30, 2008 | 05:25 AM
Cixi's Avatar
Thank You.
Do you think is an Always On cable set the one showed in the manual?
I need a 12v continuos and a 12v that is supplied only then the car is with the engine runnning or the key in on position.
Old Jan 30, 2008 | 10:37 AM
E550 Coupe
I'm not sure if it's continuous, I tested it with the ignition on.
Old Jan 30, 2008 | 11:03 PM
ghostdunks's Avatar
the ones used for the install of the smarttop modules are "Always On" wires. they need to be so that they can always be running so that when you trigger the smarttop remotely, the smarttop can intercept the signal and trigger the roof, and without the engine running.
Old Jan 31, 2008 | 12:19 AM
E550 Coupe
aah, good point!
Old Jan 31, 2008 | 06:13 AM
Cixi's Avatar
Do you know where I can get the +12V alwas-on and +12V while key turned in 1 or 2 position?
I need in 4 days since for that date I have to install the sat anti theft system under the foot of passenger
Old Feb 1, 2008 | 01:01 AM
ghostdunks's Avatar
yep, pointed out the possible points in that thread already
Old Feb 1, 2008 | 05:08 AM
Cixi's Avatar
Where?
I did not see that
Old Feb 5, 2008 | 01:19 AM
ghostdunks's Avatar
3 cables you could find:
1 Positive alway On - I think any wire coming out of the driver side fusebox in dashboard are always on - get a add-a-fuse-circuit adapter and piggyback onto any of the fuses
1 Positive On when the car is running - I think you're looking for an IGNITION one, and you can either tap it from the cigarette lighter wire OR there is a fuse in the fusebox in engine bay which only gets turned on when car is on, think its the one marked cigarette lighter/accessory. Same thing as the always on wire, use a add-a-fuse-circuit adapter
1 Negative - easiest of all, just run the wire to any grounded metal point.
12v always on = 1 positive always on
+12V while key turned in 1 or 2 position = 1 Positive On when the car is running
