SLK/R172: Just bought a 2012 SLK!
use the search for part number 1728800082 and you'll get them for $131.25.
You might want to wait until I get my order to see if that is the correct part and how they look.
Also on that note what about the wind screens (glass/plastic ones not a net type)? ? I noticed one 2012 SLK on the lot had two small triangle looking windscreens behind the two headrest roll bars. But the brochure also shown there is also a center windscreen that goes in between the roll bars. Can we order these online also and save money?
I have the factory 'Air Guides' plastic wind blocker that you saw. The mesh screen that fits between the roll bars is standard. The Air Guides require cut outs in the chrome roll bar covers so if you order them after you get the car I'll bet they will be very expensive. BTW, the Air Guides cannot be currently be ordered with the car.
The 09 SLK 350 that I traded in on the 2012 SLK 350 was artic white, too.
Here are some pics of my car:
http://www.slkworld.com/slk-r172-gen...-new-ride.html
If I recall correctly looking at the 2012 slks that were on the lot it looked like one of them had the slots for a wind blocker in the middle and one slk didnt have them. Now I'm worried mine wont come with the slots and I wont be able to get anything? Does yours have 2 tabs in the middle bottom or 4 tabs, 2 in the middle bottom and 2 on the sides?
Also why do you need smart top roof module for a 2012? The dealership showed me on a 2012 that holding lock or unlock will open the top without being in the car. Unless you want to use it to operate the top while driving?
Thanks!
Not two weeks ago I purchased a 2012 SLK 350 with black exterior and ash-gray interior equipped with the premium package. Three days after I did so, the car had to be towed because a sensor in the vario-roof malfunctioned, leaving the roof not fully closed and frozen (the trunk electronically unopenable too). When I got the car back days later it kept stalling when I moved the gear shift from P - D, park to drive. For more than twenty minutes it wouldn't move. The only way to get it going was to move in reverse and then it went into drive without a problem. The car is now back in the service department, a sensor has been taken out of a demo SLK, but there's an ominous silence from the department about the status of the engine. The car with just 600kms on it has been in my possession for under two weeks. Has anyone been in this position with a just-purchased vehicle? Any advice much appreciated.
so i called the dealer who i purchased it from and told them the situation. I told them I am leaving this car at the nearest Mercedes dealer and you can pick up your car. I don't want it. I assume they voided the transaction. from purchase to return, it probably was about 6-7 days. hope this helps.
I bought the car two weeks ago today ...
Another friend of mine was also buying an ML diesel just like mine at the same time I got mine. His was fine while mine had issues. I think the dealership wanted my continued business since I purchased 2 cars at the same time and have probably brought 25-30 car sales to them in the past year.
In my opinion speak with the area representative and MBUSA (Not sure where you are located) and see if it can be resolved that way.
