AMG engines come broken in?
On page 272 of the SLK manual (The first 1000 miles), in the far right column, it does give "Additional instructions for the SLK 55 AMG" stating to not exceed 85 mph and to avoid engine speeds above 4500 rpm for the first 1000 miles.
Also, when I picked up my car, there was a sticker placed on the inside of the windshield in front of the driver that said the same thing.
JS
Can you ask your specialist to explain?
The idea of engine break-in is to allow the engine's components time to adjust their imperfections. As manufacturing processes have improved, part tolerances have gotten far better. So the amount of "shaving" that parts do as they are used occurs far less than even 10 years ago.
Even though I do not think break-in is extremely ciritical, I can not bring myself to push a new engine hard. Regardless of what you believe, it will not harm anything to be gentle for the few thousand miles or so.
If you bounce the throttle off the rev limiter as your tear out of the dealership's parking lot, you can't expect the car to treat you well down the road.
Do a search on "break in" or "break-in".
It's the rest of the drivetrain (tranny, diff, etc.) that needs the proper break in, especially on the high hp cars. Enjoy!
Even if you thrash the car from day one you will probably be fine but for the sake of a few weeks of careful driving would you not rather think that you are helping the car break in more gently?
Of course, this begs the question, "what if you get your car chipped and then drive like a slug?" Does the chip change itself back to "comfortable driver" mode?
Anyway, to cut a long story short, he was flooring the car. He didn't care less about this wear in or anything else for that matter. We went around this track at maximum speed (for the distance he had) ESP was off etc... from my recollection we were at 140mph at some stages before he slammed on the brakes to bring it down to about 5mph, we then took a sharp turn and then off we went again.
He said that they may do up to 60 laps in each car, to make sure that things are in good order on each batch of stock they receive. The cars still go who they were destined for too and the new owner would be nonthewiser.
So, I still think that yes, it's worth taking it easy in your car, before you try to get the ultimate performance out of it. If you dont and something goes wrong, your warranty goes out of the window. a) Doing 140mph and then the engine or gearbox going bang breaches the instructions you got with the car given the mileage your likely to have and b) couldn't ever be considered normal wear and tear. But upon saying this, they seem pretty sure that the cars can handle this, but I doubt that a brand new car could take the high speed strain for too long, consider it's just been put together.
Thrash your car at your own risk... but if it goes bang... be ready with the credit card and for some surgery to remove your nuts, as it's going to cost you BIG TIME!!
Before reaching 1000km milege
- No engine braking
- No emeregency heavy braking
- No rev exceeding 4000rpm
- No speed over 160km/h
Before reaching 5000km milege
- No trying top speed over 200km/h
- No rev exceeding 5000rpm
I am at 14000km milege now, transmission, engine all work great , not a sign of any abnormalities since day-1.
cnt
