AMG logo on command unit?
Lamborghini Gallardo, Turbo, SLK 55, E350 4Matic, Xterra
anyone try the 3-5-7 trick?
just got mine yesterday will post up pix once i get the digi from the gf..
btw the car is SICK!
W203 slightly modified
Former Vendor of MBWorld
some slow@$$diesels
just wondering...when you have the AMG startup logo and have the audio screen selected in the instrument cluster...set the radio to AM and tell me wether you still have the AM Frequency displayed in the instrument cluster.
On the W211s it no longer displayed the AM frequency in the IC when the comand starts up with AMG.
greetingz,
greetingz,
SLK 55 AMG: this is how you do it (have not tried it yet)
get into the region menu
press 5 then 3 then 7 and hold all three down.
a hidden menu will appear.
select AMG R171 ECE
now i played around with it last night but how to get into the "REGION MENU"?
select AMG R171 ECE
SLK 55 AMG
greetingz,
greetingz,
SLK 55 AMG
select AMG R171 ECE
select AMG R171 ECE
SLK 55 AMG
Originally Posted by jcanabal
Mine is an '06 with build date 8/05....no problems...
Pics...
Pics...
2006 SLK 55 AMG
Originally Posted by SLK 55 AMG
Can you tell me step by step how to do this trick? I tried it and nothing is working. I hit the R button on side of odometer (if that is the region button) and then i hit 5 - 3- 7 and held all 3 down a thing pops up but there is no R171 AMG ECE. Can you even tell me where the button are located and if I have to hold a certain amount of time, etc? Thanks!
Don't have to hit the R button.
Just press the 3 other buttons and leave press for 5-8 seconds and a display will give you the options. I think there are 3 or 4 options but mine said R171 AMG USA.....let me see if I can find another post that had the pics of the display.
JMC
SLK55
wat's the region manual?
and i tried to hold the 3,5 ,7 buttons for while...but nothing happen ....the CD just changing.......
mine one is july/05 production.
THX
THX
2006 SLK 55 AMG
THX
THX
SLK55
^^ i selected the amgr171ece...but it turned back to the r171ece automatically......i just called my dealer see if they been locked only into r171ece mode, by the way where will be the amg logo appear? once switch on the radio/cd player?
THX
THX
CLS55
same problem here, i selected USA from ECE and turned off the unit. turned it back on and it was back to ECE with regular Mercedes logo... ?
Edit: AMG logo is now showing
2005 SLK55 AMG
THX
THX
Be aware, if you mess this up (and at least one other forum poster has) MB will CHARGE you to fix it, and in the worst case claim you need a need head unit for big $$$.
Turn ignition on so Screen is on (car does NOT have to be running). Press AND HOLD 5, while holding, 5, press and HOLD 3, while holding 5 and 3, press and HOLD 7 (i.e. you are holding all 3 now). Wait ~ 10 seconds.
AGAIN, use at your own risk. This gets you nothing but a change in the startup logo that last about 2 seconds. That's it.
Here is the TSB (that tells MB service to charge you to fix, and shows how to do it).
http://www.alldata.com/tsb/Mercedes-...0_P-82-85-437/
To get it too "stick" (ie. stay), you need to press OK after changing.
2006 SLK 55 AMG
Originally Posted by bloflin
It's NOT 3, 5, 7 (even though silk32 posted it that way in his original post, he corrected it, in a later post)... it is 5, 3, 7.
He is correct!! I used the second page on the posted TSB and it worked perfectly. I have to say that the first time I turned the car on and nothing; I did it again and nothing then I did it a third time (thinking I did something wrong) I left the car without the key for 3-5 min and when I turned it on......it's there!!! (too bad it only lasts a few seconds!)
Enjoy!!!
JMC
2006 SLK 55 AMG
Originally Posted by DbleNckel
can this be done on a C55's command unit??
some slow@$$diesels
I imagine is the same so, shouldn't be a problem. (But...I'm no expert...)
greetingz,
2006 SLK 55 AMG
C55 comand in the US is an alpine unit...R171 comand is the same comand as the W211 and W219 comand and is manufactured by becker...completely different units.
greetingz,
greetingz,
Trust him...he is the expert. I thought they were the same.....I'm wrong!
05' MB C-dblenckel
greetingz,
greetingz,
