HPS S/C for V8 5.5L
an '06 C55 owner has recently put in a HPS Root s/c in his engine and experienced a 147 HP initial boost without any other mods (ECU etc). If this actually works well, i'm gonna throw that puppy under my hood enjoy the read
if anyone has experience with HPS, share it!
#1, your link doesn't work?
#2, you can't put a blower on your 5.5L powerplant without adjusting the A/F ratio or you will blow your motor (becomes too lean & can detonate without an ECU upgrade to enrichen the mix)
#3, why would you opt for 147 Hp when you can obtain approx 200 hp from Kleemann (who is more experienced with this powerplant & has been modifyig ONLY MB vehicles for over 20 years)? HPS could have a lower price, but will likely cost you more via the headaches & possible TUNING problems you will encounter.
I advise you stick with an established aftermarket firm such as Kleemann (or perhaps Renntech) or you may ruin your entire SLK experience. Proper tuning of a car after modifications is complex & should be entrusted to firms that have a proven track record working with the MB 5.5L powerplant IMHO. Its not just the A/F ratios, its the interaction with all the existing MB engine control module parameters which must operate within a specific tolerence range. If any range parameter is violated, you've got instant problems (one of which can cause your existing ECU to reset to stock default parameters - not good).
-Matt
I think HPS is worth looking into. I think always keep an open mind to the best power & technology as Ted Balwin posted in your link (although he is not correct regarding the lack of a Kleemann Warranty as they do indeed Warranty their products & installation for 1 year).
I believe perhaps the stock ECU might suffice up to low 400 rwhp. However, after that, likely not. Increased fuel pressure via a rising rate regulator & a different base programming to add fuel up top are neccessary). So, to sum it up, you should:
1) confirm if HPS is reprogramming the stock ECU for proper fuel delivery
2) realize that later modifications such as headers/exhaust would require an upgraded ECU (again, since even if HPS performs this task initially for the blower they offer, they don't offer a full line of products nor the associated ECU upgrading/reprogramming to ensure these other modifications have adequate fuel).
Pal, its your car. I just think after shelling out $70k for a new SLK you might want to reconfirm the above so your HPS choice is a wise one? It could indeed be a great choice - maybe give them a call & talk a bit so they can answer some of your questions regarding power, adequate fuel delivery/ECU programming, Warranty, etc. Good luck & see you!
-Matt
thanks again
-nishi
Ted
Ted
-Matt
I don't mean to say that folks on this forum are unreliabile, exact opposite! I'm just saying it's better to get the word direct from the horses mouth
Nishi, nobody said HPS covers the engine.
As I said before, call the manufacturers. I believe its always best do your own research first & use others' input to butress (not define) your own decisions. At least you can feel good about your purchase - you will have done everything you can (within reason) before making your personal decision. See ya.
-Matt
I can tell you this. My car before the SC and after is like night and day. It's not even remotely the same car. I've read many of your concerns about the customer service, overheating, lack of power, noise,etc regarding HPS but so far I can't relate because I don't have a single complaint or disappointment. I commute 80 miles a day and have never experienced overheating in Southern California traffic. I have not tracked the car yet but have floored it on the freeways late at night with no heating, noise or lack of power concerns. I have'nt test driven a Kleeman, Renntech, Brabus or Carlsson SC so I can't compare but I know this car has plenty of power. I know the others are established, reputable and their numbers are amazing (i.e. +200 hp) but I actually think I can get close to that number if the mods below workout.
I have gotten plenty of advice on what to be aware of with any further upgrades to my HPS S/C . (Pressure gauges, cooling mist, larger intercoolers and heat exchangers, fuel and water pumps). I'm sure Bill K at HPS already covered this but I will ask him again. The Auto Show just closed 15 minutes ago and tommorow they will begin modding my car with the following:
1) Pully Kit
2) Larger Fuel Injectors
3) Upgraded cooling (see above)
4) ECU re-tuning.
Adam and Bill are doing this free of charge for lending my car for the show.
Bill told me emphatically that there will "NO RISK WHATSOEVER" with these upgrades. Adam reminded me that this will not be offered to other customers because I am basically helping them with their R&D. Adam has not voided my warranty which DOES cover the engine and not just the SC while this upgrade is taking place. They currently have another CLK55 that was successfully upgraded a little while back that Bill claims makes my car look like it's standing still. I am expecting/hoping for a minimum of an additional 50whp being that my car dyno'ed at 414whp with only 600 miles on it. When I get the car back next week. I will post my new dyno's and report back on how the car is running. I am also planning to install the Quaife LSD's AND get an original DTM Kit from Germany. I did not go with the HPS because I lacked the budget, I just wanted to deal with a sophisticated and experienced high precision, high-tech manufacturer (Aerospace Manufacturer supplying engine components to NASA, Boeing, etc..) that was only 2 miles from my workplace which is also an aerospace manufacturer. If I have any questions all I have to do is drive down to see Adam and Bill personally during my lunch hour.
I will report back and be extremely honest. If I am not satisfied for any reason I will not be bashful to say so but thus far the HPS gang has been great!
Robert
Robert
1) You believe the "absolutley no risk" comment?!!!
and
2) No modifications void a warranty...but good luck getting MB to cover it if something goes wrong...
For everyone else, I would say stick with Kleeman...i dont think they are using customer cars for their R&D...
http://myhps.com/clientuploads/pdf/C...-05-Rev.A1.pdf
............HPS's itself as a company is using his car for R&D by installing the additional mods. I think this is a different situation. It is very hard for people in the MB community to realize that s/c's are not that complicated and have been in use for decades, hence other companies beside the annoited ones, can do a job.
Ted
So far Penske, Rusnak and Fletcher Jones MB have all agreed to honor my warranty. As a matter of fact I just had my first Service done at Penske MB 3 weeks ago and they checked the tuning on the SC with no concerns.
I just thought that it would be beneficial for forum members to evaluate ALL of the Benz Supercharging options with as much information as they can get.
If I ever find the HPS SC to be deficient then I would not hesitate to switch to another Brand since budget for me is not really the issue but so far I have no complaints. If my C55 upgrade works like the CLK55 then HPS may be introducing a GEN III in the near future or an upgrade kit to the GEN II for those of you who own one now. That's just my speculation since HPS is silent on this for now.
8lbs of boast is also easier on the engine or if you want to run 12lbs with a turbo your FWHP would be 650 or so.
CLK55s have an 11:1 compression ratio & do not requre 12# of boost. Case & point's Kleemann's attains that power with 7 lbs on the CLK & SLK powerplant (no headers/exhaust, cams, etc). If you try 12 lbs on a an 11:1 ratio, your engine will last about a week (this is why high boost cars have low CRs).
-Matt
-Matt
However the underlying issue is that turbos and a more effecient alternative that supercharging. Do you disagree?
Each has its pros & cons. I own/experience both & they each work well for the applications they were designed for IMO.
See ya,
-Matt
