SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
RENNTech SLK 55 - SLK55R's car
Old Nov 9, 2006 | 09:29 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Here you go guys,
Renntech SC and headers. Videos of Jesse's car can be found on our gallery.
www.euroelitesonline.com
Old Nov 10, 2006 | 07:51 AM
Shinigami's Avatar
SLK 55 AMG
Is that RWHP or at the crank?
Doesn't seem very much because Kleemann promises 500hp with just the SC installation...
Old Nov 10, 2006 | 07:57 AM
alroumi's Avatar
G55, G500 & SLK55
I think its RWHP, 399 is quiet good on the wheels.
I assume its 470 to the engine with the S/C and Headers if it lost 18% due to the drivetrain.
Old Nov 10, 2006 | 04:01 PM
Yellow R1's Avatar
'93 RX-7, SLK55
Correct - its RWHP - its a Dynojet guys.
Jesse - good numbers! Your car is putting down stock Viper GTS numbers & weighs in about the same (~3,400 lbs). You also have lower drag & a 7 Spd tranny which also help acceleration. Good numbers Jesse.
-Matt
Old Nov 10, 2006 | 04:42 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
happy with the results
Thanks matt, I"m pretty happy with the numbers as is.
This is just a breakdown for everyone from premod dynos to current and also what Renntech had up on their site. (Also remember that these are on different days but the temp and humidity weren't off by that much. )
MY premod dyno is at :
https://mbworld.org/forums/showthrea...highlight=dyno
It showed 299.78 max HP and 307.14 max torque.
The stock SLK55 crank numbers are supposed to be 355hp/376torque
Using this I'm calculating the correction factor from crank to wheels for both HP and torque.
355 x X = 299.87, X = 299.87/355, X = 0.845 HP correction factor
376 x Y = 307.14, Y = 307.14/376, Y = 0.817 Torque correction factor
Post Mod dyno numbers at wheel
X1 x 0.845 = 399.43, X1 = 399.43/0.845, X1 = 472.67 HP at crank
Y1 x 0.817 = 427.79, Y1 = 427.79/0.817, Y1 = 523.61 Torque at crank
At the wheels I gained 99.56 HP and 120.65 Torque
At the crank I gained 117.67 HP and 147.61 Torque
Renntech numbers are shown at the crank :
http://www.renntechmercedes.com/PDF/Models/R171_SLK.pdf
They say that with the mods I've done I should show a 118 HP gain and 107 torque gain.
I think this puts to rest Renntech posting inflated numbers.
Old Nov 10, 2006 | 04:54 PM
EUROTEK//AMG's Avatar
German
WOW!!! Great numbers !!! congrats!!! 399 RWHP on such a small car..that thing must move Are there any more upgrades that can be done to hit 450 RWHP ? cams..
Old Nov 10, 2006 | 04:58 PM
SLK55R's Avatar
450rwhp
For Renntech ... I'm not sure. I'm positive that I could easily squeeze another 20 from removal of precats but I'm not sure what else would help. I've asked about TB but they said that since this is a low boost pressure system ... they don't feel that the TB would help a lot. Cams would be another option but they won't give another 30 RWHP.
I think for me the next steps won't be in additional HP. I'm going to start lightening this car. Personally I think this is one of the few Benz's that reducing weight should help significantly.
Old Nov 10, 2006 | 05:20 PM
JamE55's Avatar
Out Of Control!
Awsome numbers Jesse! Just curious how HP the high boost kit produces and what makes it different? Also you can always run on race gas which adds another 15hp. At least that's what i got. Cams helps from mid to high rpm.
Old Nov 10, 2006 | 07:29 PM
SLK55R's Avatar
high boost
I'm sure Renntech could make a high boost kit for the SLK55 but there would be a lot of engine modifications. Also I'm not sure the 7G tranny can handle a high boost application.
race gas ... yes its something that I add to my car already ... I'm trying to always have at least a 93 octane mix. RIght now though the ECU is programmed for 91 octane. I've already requested a 91. 95. 100 ecu program so that I can switch out when I want to.
Old Nov 10, 2006 | 10:21 PM
dsb's Avatar
dsb
'06 slk55
Awesome results Jesse. That thing is a monster. I want to see it run!
Old Nov 10, 2006 | 10:24 PM
German
Post some vids of this beast in action
Old Nov 11, 2006 | 12:50 AM
We will take more pictures and videos of Jesse's car soon.
Old Nov 11, 2006 | 01:06 PM
Shinigami's Avatar
SLK 55 AMG
hmmm, but if you remove the headers, you're only developing about 450hp, whilst Kleemann says that theirs gets yoyu 500hp without the headers...
Old Nov 11, 2006 | 05:19 PM
SLK55R's Avatar
500hp
People choose tuners for their own reasons. I've chosen Renntech and I"m extremely happy with them.
