Just Got my slk55 need help..
If you want to drive fast make sure not to redline the car and shifter slightly earlier so the gearbox/ecu gets used to your driving stlye.
The engine is allready broken in at AMG on an engine dyno its the gearbox that isnt broken in.
Good luck and Congradulations on the new car, that is a good New Years gift.
Exactly, unless the IS350 you raced had some sort of forced performance.
The engine may very well have been broken-in at the AMG factory, but other components in the car have not. The engines are often run as-is (i.e. out of the car) on a bench for several hours at high speed to check for any problems. The gearbox is not taken through such a routine.
Thus, if you do a hard break-in, the transmission and drivetrain may suffer.
Also, the 7G gearbox adapts to ones driving style. So why don't you first let the car bed in fine for a thousand miles, and then see what it has in store. The 7G can also be "reset" to the high performance/responsitivity status with a few button presses.
Be careful when "racing". Don't want more roadkill then necessary.
How do you rest it
It can? I searched the owners manual but NADA. I've heard of the reset of the ECU but that's not what you are talking about. Please tell us how ol' wise one.
