SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
remove engine cover
Old Jan 2, 2008 | 11:43 PM
MercSpeed55's Avatar
Slk55
remove engine cover
how do i remove the engine cover so i can put my green filters in ?
Old Jan 3, 2008 | 02:16 AM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
Lol........if you can't even figure that out, I doubt that you can figure out how to put in the filters.
Old Jan 3, 2008 | 03:24 AM
ellimb's Avatar
A200, Slk350
mercspeed55
Search for thread here or in SLKWORLD.COM ABOUT GREEN filter
Old Jan 3, 2008 | 11:54 AM
Ynot's Avatar
MBZ SLK
Basically pull straight up and unlatched the metal clip on top, detail instructions on Slkworld.com.
Old Jan 5, 2008 | 09:52 PM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
Please see my previous post with photos on how to remove the cover and change filters at
http://www.benzworld.org/forums/r171...er-photos.html
Old Jan 5, 2008 | 10:27 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
The cover should easily snap off
Old Jan 5, 2008 | 10:30 PM
porschetobenz's Avatar
porsche 911
I just put my green filters in. I am hearing a slight noise from the engine when the car accelerates. I believe it to be the lifters. I hadn't noticed it prior. It's not offensive, just barely noticeable. the guy who put them in said it's probably due to the increased air flow. could there be a correlation?
Old Jan 6, 2008 | 01:53 AM
Ynot's Avatar
MBZ SLK
It is a bit louder with the greens, should be normal, if you are concern, re-check to see if everything is installed correctly, make sure it's a tight snug fit.
Old Jan 6, 2008 | 11:28 AM
porsche 911
Thanks YNOT. The sound isn't a bother. I can barely hear it but I do hear it....also, the shop(authorized MB independant shop) did an oil change. They used Pentosin Pento High Performance oil. When I asked why not(YNOT, get it) Mobil 1, he said that this oil is high performance synthetic and used in germany for MB's and BMW's. i looked it up and it indeed seems fine but has anyone heard of it/used it? thanks.
Old Jan 7, 2008 | 10:05 PM
MB_Forever's Avatar
Pentosin Pento High Performance Oil
Pentosin is a high quality oil, I've heard of it before....... but I've never heard of an actual MB dealer recommending it or even using it
Mercedes recommends Mobil 1 in all their products, and even have an explicit sticker stating that under almost every hood of their cars.
Old Jan 7, 2008 | 10:46 PM
Ynot's Avatar
MBZ SLK
Never heard of it, my dealer uses Mobil 1
Old Jan 8, 2008 | 10:53 AM
porsche 911
I was already at the shop so I just let him do it. But I did say I thought Mercedes recommends Mobil 1. And he said that this was better. That they use this in germany. I don't know. I'll probably get mobil 1 next time. he recommended oil changes every 6,000 miles (i'm in south florida)
Old Mar 8, 2008 | 04:26 AM
Untertürkheim's Avatar
The Pento High Performance 5w-40 is excellent oil. It meets MB Spec 229.3, and I use it myself in any cars that do not require the new 229.5(1) specification.
As far as the M1 stickers, it is just a marketing deal for the US market, those stickers are not found in Europe (and I doubt anywhere else). More information here:
http://www.pentosin.com/shop_produkt...7&pid=667&vid=
