How does the 55 engine compare to 63?
I currently have a C63 as my daily driver and am curious how the 55 engine compares to the 63. I know the SLK is lighter than the C63, but I'm not sure by how much.
anyone have a chance to compare the two? The only 55's close to me are private sellers and i don't want to bother them for a test drive unless I'm really serious.
Also, any model years to stay away from? They don't look like they've changed much since 2005.
http://www.dragtimes.com/compare2.ph...onName=Compare!
The C63 is higher revving and has a more aggressive exhaust note. Handling and transmission are also probably a little better in the C63. The SLK55 has close to a 600 pound weight advantage, but with less hp, it is essentially negated. C63: 3993lbs. SLK55: 3395lbs. I had numerous opportunities to drive the C63, but never back to back with an SLK55 so I have limited insight into the fine points regarding their driving dynamics. The SLK55 definitely has it in the looks department. I get lots of compliments and shouts on the street.
With a couple of bolt on mods, I have been able to keep up with with my friend's unmodified '06 W211 E55 (which is faster and heavier than both the SLK55 and C63 stock). See video:
http://www.youtube.com/watch?v=cmQ94HHK7BE
Regarding the year, it depends on whether you care about the facelift or not, and whether you want the 6-piston/4-piston brake setup. Personally, I would get an '07, since I think that is the last year they offered the 6-piston brakes on standard SLK55s. I think they are still available on the 030 performance package versions, though. Reliability-wise, I have had a few issues: leaking valve cover gasket, faulty CD-changer, and most recently a faulty ESP Control Module. Though they added up to a couple thousand in repairs, they were relatively minor issues. In general, I think the 55 motors are pretty reliable. My friend has put over 60k daily driver miles on his supercharged 55K, with no issues whatsoever. Now if torque is what you are looking for, go with the 55K motor in the SL55 (I'd recommend '06 or later).
My SLK55 is almost fully loaded, but here are a couple of options I would recommend: air scarf (for top down motoring in colder weather or evenings), navigation, digital climate control.
Good luck with your choice, and post some pictures when you get it!
If you can find a F/L '55 with the 030 package, you'll have a great car. If you don't like the F/L look, go for a my05-my07 with the proper AMG brakes - I catch P-Cars out regularly with my ability to stop!
EDITED : So for sure go drive a '55 before you get really excited. The seats are a "love 'em / hate 'em" sorta thing, although I do find the AMG seats to be more comfortable than the non-AMG. If you are over 6 feet, you'll spend some time getting comfortable. I'm 6"2', and have driven from one end of the UK to the other (about like driving across Texas, but more traffic), and from Louisiana to CA and Maine - so obviously I find the car quite comfortable.
C63:
http://www.youtube.com/watch?v=A9lip...el_video_title
SLK55:
http://www.youtube.com/watch?v=GCyL0...el_video_title
C63:
SLK55:
but I'm certain I won't be pulling away from a C63.
but I'm certain I won't be pulling away from a C63.In the videos, it confirms that the C63 attains a slightly higher speed on the straight, compared with the SLK55. The lap times are essentially a wash.
A stock SLK55 is definitely quick, but a Stage 3 or Stage 4 SLK55 is a monster, with that much power and such a low curb weight, it really gets moving down the road. Getting the SLK55 to 400HP+ is real easy and the results speak for themselves. It is a great platform as long as you don't need two extra doors and you are not very tall. If you are over 6ft, the SLK is probably not for you.
hope that helps
