Kleemann up to 560 hp for V8 5.5 (link inside)
1 Post
SLK55 AMG
damn, thats too much! a stock slk 55 is really more than enough for the street and daiy use. and in autocross you dont need that power, i remember i used to get my Mroadster , 1 and 2 . seldom i was using the 3rd gear!
I strongly feel you would have to retrofit the five-speed transmission to take advantage of those power levels. Either that or you are going to be running through tranny's left and right. That is unless you know something that Mercedes' R and D department does not.
Time will tell...
The 7 speed is currently in the SL500 and the S class weighing nearly more than 600 lbs and 1000 lbs than the SLK, respectively. For the limited edition AMGs retooling costs may have been a factor in limiting the current production to the 5 speed. Let's see what happens next year.
Originally Posted by ajoe
Can the 7 speed transmission handle this power???
SLK55 AMG will come with the WA700 7G- supercharged cars, as mentioned, do not come with the 7G- yet. From what I have been able to gather the reason for this is that the Ravigneaux planetary gear set is the concern for huge shock loads. AMG SC EGS shift programs can be pretty abrasive (hard) on up shifts, the concern is the secondary, or "short" planetary gear in the Ravigneaux gear set may not be able to handle the shock load of 600+ lbs ft on a 4300 lbs car. A SC specific variant is planned- with longer (larger area) short planetary gears. Introduction date is unknown to me.
