SLR/C199/R199/Z199: Transmission shifts HARD
There are other mods you can do like lightweight crank pulley which help smoothen shifts but most SLR owners don't really mod their cars so thats understandable.
I will say though that I recently put Royal Purple in my engine & differential and surprisingly my tranny shifts much smoother now I don't know if that will help a bit but it might and plus it won't void warranty so its worth a shot.
It is not spec,it is not approved and you are suggesting someone with an 08 put it in and it won't void his warranty?
Where do you come up with this stuff?
Don't go bringing up the O'keefe act
For you have not read it if you think it pertains to royal purple.Call Royal Purple they will say use
MB spec fluids
From Mercedes Benz On Oil Related Failures
The MMS history should be accessed via SDS. The MMS history read out should be used to confirm the
maintenance history of the vehicle. If the MMS history read out shows that the vehicle was improperly
maintained, i.e., the maintenance intervals were materially overdrawn; and in addition, if the review of all
the customer's service records indicate that at the time of the subject oil change, engine oils not
approved at the time the change was made were used, the vehicle is not covered by the Mercedes-Benz
Limited Warranty. Additionally, the O'Keefe Class Action Settlement Service Commitment applies only
where the oil used was one that was approved at the time of the oil change. Further, please note that
under the O'Keefe settlement (1) there will be no coverage where there is evidence of vehicle abuse or
neglect in failing to properly maintain the vehicle according to MBUSA's recommendations including the
recommended service schedule
In other words you need not use Mobil1 but you better be using an mb spec oil or fluid in your warrantied engine ,transmission or differential.Unless you like a big fat denied on your service request.
Maybe you like to gamble,I don't think the op with the 08 needs to risk it.
OP ,Go have your trans software program checked for recent updates and proper shift points.
So in summary, it's a "good" thing
The viscosity, detergents, and other key elements will work with or against your engine and transmission. If you use the wrong one, it will work against it.
