SLR/C199/R199/Z199: iPod & Bluetooth options?
Curious if anyone has seen a solution to get both iPod and bluetooth connectivity in an SLR yet? Would be much obliged to hear what options are out there.
--Dan
Pioneer DEX-P99RS. It has a very clean aesthetic and has the right feature set (bluetooth, ipod, etc), good integration into stock controls and mic placement, etc. It's not a simple head-unit swap, though, since you need to get an external amp (not built-in). This means that it's worth a couple extra bucks to swap out the wiring, speakers, etc. You can still achieve "good" sound keeping the stock speaker locations and the stock look. All in, you can get a nicely finished solution done for <10k.
For those looking to add nav, you'll need another solution. The single din motorized screen systems seem clunky to me and NONE of them look ok.
--Dan
--Dan
I'll check the photos of the SLR I was in before to see the phone set up. If it has that MHI cable then you can just unplug it and use the OEM bluetooth- plug and play.
ice UNI-150-PRO FM Direct Modulator with RDS Text. I asked my local MB dealer to do the install. I just received a call from them that everything seems to be in order, except that the radio sounds terrible. I will head down there tomorrow to investigate further and post my results then.
ice UNI-150-PRO FM Direct Modulator with RDS Text. I asked my local MB dealer to do the install. I just received a call from them that everything seems to be in order, except that the radio sounds terrible. I will head down there tomorrow to investigate further and post my results then.Any update on this? Can you use the ipod and bluetooth? Really interested in doing this for my vehicle, so any info would be greatly appreciated.
Best of luck!
