SLS/R197/C197 AMG: Bang and Olufsen retrofit
From what I understand, they would have to run new wiring to all of the speakers. I know the cutouts in the dash for the B&O speakers are different so you would have to replace that portion of the dash. I believe the enclosures are unique, and as are the speaker covers. I would be willing to bet buying the parts after the fact will be more than the cost of the option. VERY rough guess (and probably very optimistic) for parts and labor would be at least twice the original option price so ~$13k, but it might be more depending on how much of the interior would have to be replaced/upgraded and how hard it is to access the wiring, etc.
1 Post
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
expect it to be $10k or more easily. The B&O option on the SLS from what I remember was around $4500. But if you are going to install you are going to have to consider labor charges and probably some wire replacements.
e90 M3
It's quite expensive, then again I didn't expect it to cost the same as the factory option.
Is the sound really worth it compared to the harmon kardon system?
2004 SL55, 2015 A250d, 2016 GLC250d
The door panelling and rear parcel shelf have to change too. And getting the wiring loom too is very hard. If you are going to do it, fit reversing camera at the same time whilst you have the wiirng ducts accessible !
Richard
Richard
e90 M3
Its like getting some Dr Dre beats headphones then getting some B&O or Bose headphones, they sound more flat, and clear, as the bass frequencies have been turned down.
e90 M3
100 watts is nothing. Thats what I have in my bedroom coming from my 2 Sony speakers. If you can/want to upgrade, I would. 1000 watts will blow your mind. And B&O have EXCELLENT sound quality. Might take a while to get used to, if your used to using slightly cheaper sounds systems, which normally have more bass frequencies. B&O Is for Audiophiles, crisp sound. Might sound flat to begin with.
It does cost around 10k to retrofit and I think it cannot be calibrated in canada, only in the states from what I hear but I'm not sure about that claim.
Finally, I will wait and probably do a custom setup, maybe a mix of McIntosh and JBL.
If you guys have suggestions of setups that would sound as good as the engines, post them.
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Let’s clear up some misinformation here:
watts is meaningless without knowing the efficiency, or sensitivity of the speakers.
My $200k audio media room has a 3 way horn system that can easily reach 120 dB of sound volume - and it’s powered by a grand total of 8 watts. 8.
It could be that the standard 100 watt system has more sensitive drivers than the B&O. Reports from owners with the B&O have largely agreed that the sound quality is not great and it’s not worth any extra cost.
Personally I think the drivers look cool, but I doubt there’s much sound quality improvement - most owners agree.
