SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: Warranty Expired?
Old Sep 10, 2016 | 08:12 PM
traimpz348's Avatar
2012 SLS AMG, 2002 Ferrari 360, 1956 Austin Healey
Warranty Expired?
How do you know when your warranty expires? Are all 2012's expired at this point?
Old Sep 10, 2016 | 08:29 PM
ItalianJoe1's Avatar
2003 CL 600
Dealer runs your VMI (vehicle master inquiry) to determine warranty start and end date. It can be from the production date, so in that case yes any MY2012 car is at least 4 years old. Some cases I see it triggered from the sale/in service date, in which case if the car was bought late in 2012 it would still be in the last part of warranty.
What are you trying to get done?
Old Sep 10, 2016 | 08:32 PM
traimpz348's Avatar
I hear this awesome ticking noise from the engine... (it is cold)
http://www.trainsimple.com/IMG_1716.MOV
I'm hoping it's not a huge expensive problem...
Old Sep 10, 2016 | 08:36 PM
2003 CL 600
Does it go away when warmed up? It's normally lifters on the 6.2L engines. Not really going to affect anything but yes it sounds bad and if you can get it fixed under warranty that's always nice. Call your local dealer and have them check your warranty eligibility.
If you are barely outside of your warranty, but have good history with the dealer (services done there, etc), they can try to goodwill it if it's reasonable. If your car has been out of warranty for 6 months or so it probably won't happen. Always worth a shot though.
Old Sep 10, 2016 | 08:37 PM
traimpz348's Avatar
Cool thanks. If I can't do you know how much it might cost?
Old Sep 10, 2016 | 08:56 PM
Sandy Eggo's Avatar
'00 SL600
Not driving it much? That does sound like lifters.
Try this (can't hurt):
1. Buy a bottle of this - http://amzn.to/2cfPZuQ
2. Dump required amount in gas tank.
3. Fill / top-off tank with fresh gas - make sure it's quality stuff and highest octane available.
4. Give her an "Italian tune-up". Wait for Oil temp to reach at least 175dF and then find an open stretch of road to drive in the higher end of the rev-range for 15-20 minutes. Vary your revs and gears (i.e., don't just stick it at 6,000 and leave it).
I'll bet you a donut that the noise goes away. If it does, promise the AMG gods that you'll drive her more often.
Old Sep 10, 2016 | 10:56 PM
traimpz348's Avatar
Will try. Thanks for the advice... and yes you're right... not enough drive time at all.
Old Sep 11, 2016 | 12:57 AM
2003 CL 600
Gas additives won't help, but an oil additive may. Although, if you baby it all the time or don't drive it at all, the oil can get funny. There was another thread on here about people addressing the lifter noise with a different (non mercedes but approved) oil, which says it's not a real fault just a lack of exercise. Like any other sports car, they work much better when used as intended.
Old Sep 11, 2016 | 08:24 AM
traimpz348's Avatar
Ok. When I do drive it, I don't really baby it. The last two times though were just to the grocery store and barely got up to temp, so of course I took it easy. I'd say the average is every two weeks I take it out, but there was a stint were it was once every four weeks.
Multiple cars, and work, sometimes make it difficult. I'll just make sure to take all my cars out once a week from here on out (at least until winter).
Old Sep 11, 2016 | 10:11 AM
Sandy Eggo's Avatar
'00 SL600
Re: gas additives. Maybe, maybe not. Fwiw, I did say "(it) can't hurt". Cheap stuff and I've always had very good results using the RedLine gas additive. If nothing else, it'll do wonders to help clean off deposits due to running infrequently and not fully up to temps.
I get you. Good problems to have. The Rx is to get up at the crack of dawn on a Sunday and take the very long way to Starbucks. Once you arrive, you'll find you really don't need the caffeine any longer since that W159 engine has made you all jittery.
Old Sep 11, 2016 | 01:25 PM
traimpz348's Avatar
I owe you a donut : ) Local shop had redline. Did the "tune-up" ... no more knocking sound!
Thanks!!
Old Sep 12, 2016 | 11:11 AM
Sandy Eggo's Avatar
'00 SL600
Thanks!!
Good stuff! The real test is does it still make the noise the next time you cold-start the car. If not, then I'll take my donut!
Old Sep 13, 2016 | 10:02 AM
haa's Avatar
haa
you can also check your warranty status at the Mercedes Me website once you register your car and yourself as an owner:
https://www.mbusa.com/mercedesme/index
Old Sep 20, 2016 | 07:59 AM
traimpz348's Avatar
Took the car out this weekend. On a cold start, the noise was very very subtle. I doubt I would have noticed it if I was really trying to listen for it...
Old Sep 20, 2016 | 01:41 PM
Sandy Eggo's Avatar
'00 SL600
I think it'll fade to nothing after another good thrashing.
Old Sep 22, 2016 | 08:44 AM
traimpz348's Avatar
I also found out my warranty expires on Nov. 30th. Should I try and get an extended warranty?
Old Sep 23, 2016 | 02:19 AM
NewportSLS's Avatar
SLS AMG
It's gambling really. But you will sleep better at night!
