V-Class 3 generations with first production year 1996...... V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
Viano W639 AMG brake conversion.
Old Aug 26, 2016 | 06:07 AM
Ben Bowers EP's Avatar
2014 W639 Viano 3.0 V6 CDi Avantgrade
Hi folks I have a 2014 Mercedes Viano I wish to do an AMG C 63 brake conversion, has any one done anything like this also does anybody know of any conversion kits or any parts that are available to buy?
Ben
Old Aug 26, 2016 | 10:21 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to V-Class forum...
Old Jan 24, 2017 | 06:56 AM
LukLagun's Avatar
MB Vito & C220cdi
Ben
Are you still looking to get this done one Your Viano ??
U will need E55 AMG 360x36mm discs and custom adapters to be made to fit Vito/viano knuckle. Not sure if C63 are using same discs i know size is same but offset may be different. I did try E55 AMG 8pot calipers with 360x36mm on my vito but decide to sell them. Rear setup my required custom 2pcs discs to work with oem hand brake. Unless u use SL600 or S600 rear discs then u will have to get custom adapters to be made to fit C63 calipers
Im going for 360x36mm discs with Genuine Mercedes 4pot calipers.
U can get discs for 100quid, pads will be 50-60quid and calipers will have to be modified to fit vito/viano knuckle but once they are modified u dont need any adapters.
Old Aug 11, 2017 | 08:13 AM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
Hi, Did you need calliper brackets or did they bolt to the vito hub?
Old Aug 12, 2017 | 10:16 AM
LukLagun's Avatar
MB Vito & C220cdi
No adapters needed 😃😃 calipers mounting lugs need to be machined to work with 360x36mm discs. Standard Vito brake lines are straight fit. And brake pads are slightly wider then oem one so have more braking force.
Depends on wheels spacers may be need as mine are et59 and there is only 4mm clearance between caliper and wheel.
Old Apr 6, 2020 | 06:47 PM
teamgogreen's Avatar
viano
May be a silly question what are them calipers fitted to originally what am I searching to find some?
am looking at doing a brake upgrade on my my Viano so any advice would be helpful.
cheers.
Old Dec 21, 2020 | 11:44 AM
LukLagun's Avatar
MB Vito & C220cdi
cheers.
Sorry for late response pal. Sold my Van sometime ago and totally forgot about this forum. But looking to get another one and will be getting bigger brakes fitted on it only this time front and rear.
These calipers are from Mercedes R321 SL450 AMG and will need to be modified before can be fitted. You will also need Mercedes W211 E55 AMG 360x36mm discs.
You can reuse your existing brake lines as they are straight fit.
There is another option that could be used on Vito/Viano. You will need set of calipers from Mercedes C63 front & rear ones. Discs will be 375x36 on front & 365x26mm on the rear.
Old Mar 9, 2021 | 05:36 AM
LukaszKry's Avatar
V-klasse
Hi, i am doing right now brake conversion in my V-klasse what did you mean by modifying the calipers ? I saw the total thickness difference of the vito rotor compared to e55 rotors is about 6,2mm. So do i need to machined caliper lugs to make it thinner about 6,2mm ?
Thanks for replay
Lukas
Old Mar 30, 2021 | 09:38 AM
localmade.nl's Avatar
W639 122CDI
[QUOTE=LukaszKry;8288156]Hi, i am doing right now brake conversion in my V-klasse what did you mean by modifying the calipers ? I saw the total thickness difference of the vito rotor compared to e55 rotors is about 6,2mm. So do i need to machined caliper lugs to make it thinner about 6,2mm ?
Thanks for replay
Hi Lukas , I am new here and following your conversion . if you take the discs rom an cls c218 [ hight is 51.5 mm.] do you need to modify de callipers than also?
its just a suggestion . i try to figure it out for my vito. part no brembo 09B747.51
Old Aug 28, 2021 | 03:30 PM
LukLagun's Avatar
MB Vito & C220cdi
[QUOTE=localmade.nl;8304228]
Thanks for replay
Long time since I been here
I did use e55 discs which are taller than a standard vito one and that's why calipers had to be modified. If I member right calipers been modified buy milling 4mm of the lugs. If you are going to use discs from CLS then calipers won't need modifying but will need correct spacers/shims between calipers and knuckle so the discs are perfectly in the centre.
Im going to use ML63 5pot calipers with 390mm discs but u can use same calipers only with 360mm discs in both cases calipers will need spacers between lugs and knuckle.
Old Mar 31, 2022 | 08:27 AM
Cpazole's Avatar
W639
Luklagun contacto
hola. Podemos retomar?
Old Apr 1, 2022 | 03:13 PM
LukLagun's Avatar
MB Vito & C220cdi
Sí podemos amigo. Es posible que tenga un juego de pinzas a la venta pronto todo lo que necesitarías son discos de freno
Old Apr 1, 2022 | 03:34 PM
Cpazole's Avatar
W639
Hola, tengo unas pinzas de sl500 231 pienso que son iguales. Se atornillan directamente a la mangueta de viano w639?
Después, por lo que contastes hay que poner disco de 360x36 y supongo que en función de la altura de este se tendrá que mecanizar la pinza o poner arandelas de suplemento .... es así?
y por último, tendré problemas con mi llanta 18"
Un saludo y muchas gracias
