HID Conversion Kit Special $60.00 Shipped for MBworld members
#176
Former Vendor of MBWorld
MB
Hi,
NO, 3000K is bright yellow for fogs, if you want closest to oem bright color, it's the 5000K (same as 4300K stock bulbs), it's white with light yellow tint. thanks!
Michelle
Michelle
#178
Flying Spur
Just finished installing the fogs (H7 6000K) took a bit over an hour. Going to get the D2S low beam bulbs 6000K installed later today, getting it done from a shop.
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3113.jpg)
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3114.jpg)
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3117.jpg)
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3118.jpg)
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3119.jpg)
![](http://i38.photobucket.com/albums/e138/ssonss1/IMG_3120.jpg)
Will post pics of the 6000k low beam once its done
#179
MB
Due to increasing number of HID inquiries, please allow me 24-48 hrs to respond to your PM, thread replies or Email.
I will be overseas for the month of September but will still respond to all online inquiries. If you need immediate assistance or technical support, please call 860-821-8212 between 10am-4pm PST (Mon-Fri). Thank you very much!
#180
2007 CLS 550 (Black)
Is it a straight forward install? I mean, it looks like you didn't remove the bumper and just removed screws near the fog light casing.
Where did you place the ballast? Did you zip tie it? By the way, did you use error cancellers on the fogs?
#181
Flying Spur
Got a DIY instructions on your fog install?
https://mbworld.org/forums/cls55-amg...ng-lights.html
As for the ballasts, I basically just left them behind the fog lamp, they're water-proof so i'm not really worries. I used error the error cancelers, however, when I first wired them up without them they worked fine, but when I left the car running the lights began to flicker after about 10 mins. So I ended up using the cancelers and everything was fine.
#182
Sorry, no DIY pictures. But this thread really helped and should answer the how to questions.
#183
'13 Dodge Dart, '16 Audi Q5
Just pulled the trigger on 6000k H7 and 6000k 9006 for my fogs...
I'm interested to see how the install will be on my SRT6. Should be fun.
#184
2005 E500 4matic
Is my car the only car that gets errors with these? I have an 05 E500 4matic. I have 2 kits, 1 for fogs and 1 for lows. I used the error cancelers in the fogs, but I still get errors for the right fog and sometimes it take about 5 seconds for the right fog to turn on. As for the lows, I'm not sure if there are 2 difent types of errors cancelers but the sockets do not match up. I had someone put in capacitors for the lows to stop the errors but just like the fogs, I get errors for the right low beam. Why the right? It sems that the error cancelers and capacitors are working; but only for the left side? Does anyone have an Idea why?
#185
MB
Hi,
You may need a new capacitor for your fogs, PM me your order # and I can get you another pair, one of the capacitor might be defective. Thanks!
Michelle
Michelle
#186
MB
NOTE: Almost ALL New Mercedes need special capacitor to prevent error message, so you MUST provide us with your YR MAKE MODEL in the comment area of your order for us to send you one, if you don't give us your YR MAKE MODEL we won't know. Thanks!
#188
MB
#189
MB
#191
MB
All orders placed before 3pm pST today have been shipped. Thanks!
#194
1 Post
2010 GLK 4Matic Steel Gray
The passenger side was alot easier since there is so much more space to get your hand in and move around, driver's side is PITA and much more time consuming because your hand is in such an awkward angle. And there isnt anywhere to mount the ballast, so i taped it to the wheel guard and so far its worked.
You do have to modify the retaining clip for the headlight since the HID lamp base is a bit thicker than the stock base. If you want, i did take pictures to see if my lights were installed correctly since you cant exactly tell if its in the right place...
#195
I called them and asked it it was plug and play - don't have to do anything else. The answer was yes - full plug and play- no extra work required.
So, ordered 3 sets for all lights
1. error capacitors for one set missing.
2. had to mod retaing clips.
3. had to drill lamp dust covers
4. find a place to mount those huge ballasts
5. wires too short to mount ballasts in good locations
It was easy to install initially but dealing with all the butchery to complete it was too much for me.
I guess if I had a 10 year old Japanese commuter car I would not have cared - would zip tie them or stick those ballasts to the engine cover or Inner fenders LOL.
I was promised a full refund since was not plug& play as represented.
I did return them with no hassle and receive a credit less %15 restocking which they refunded after emailing them about "full refund promised" which I thought included the shipping since it was supposed to be plug & play.
Because I'm in Canada I'm out $100 on two ways of shipping. Hmmm I guess I'm spoiled by yoox.com that prepays shipping if not happy.
I did purchase this spontaneously so my bad.
#197
1 Post
Here is the standard bulb fitting. You have to modify this clip to fit the HID bulb. To remove it, push down on the top portion and slide the top portion out of the guide slots. I also found it easier to reinstall the top portion first and try to "snap" the bottom into place.
![](http://img36.imageshack.us/img36/6765/img0574f.th.jpg)
Here is a picture of the HID bulb installed. What whiteongrey said is absolutely correct, but all those steps may add 45mins to your install. Getting them in will be the hardest part.
![](http://img9.imageshack.us/img9/4620/img0585rw.th.jpg)
Hope this helps...Good Luck!
#199
Hi, I received the HID kit today, but the kit looks like for other car, NOT for Mercedes, because there is NO resistor built in. When I put down the order on web, I put down the kit is for my 2007 E350. Can I send it back and get the right one ?? my order number is 1520.
#200
Check your packaging as my resistors came separately from the ballasts in the same packge though. You have to connect the resistors to the ballast and the bulb...hope that helps.
