ABS...BAS/ESP WARNINGS!!! Failure
OK. During normal driving and moderate traffic, my Info. screen goes crazy! Indicating Failure Warnings... ABS, BAS, ESP. Any help with possible causes and cures would help, so I can avoid the cost of 'Discovery' at the shop.
2000 E55
Thanks.
BTW. The owners manual says the systems BAS & ESP, will fail/disengage/go offline??, if there is an ABS failure. So then would a brake job, which I am due, correct an ABS failure?
BAS (brake assist), ESP (electronic stability) and ABS (anti-lock brakes) are the mere things keeping you alive in that car.
if not, mostlikely just a sensor might be out,
if you don't own a scanner, go autozone, they'll pick up the code for you for free, then you'll know for sure which sensor is out
"EuroSport" Thanks for the heads-up on AutoZone. Battery has not been recently disconnected. However in one of my personal quest, I removed fuses to various components in a failed attempt to restore my CD changer. (don't ask)...
Thanks to both of you...
When its your first MB, owned only a few months, and ignoring all the rhetoric; "don't buy", "very expensive", "high maintenance", etc., you can understand my thoughts and mild panic.
But I am grateful for this and other MB forums, its members, moderators, and sponsors, who willingly share.
RJ...Still a Newbie, and I'm glad. 'Cause the youngest is always spoiled!
After doing some thread search, I found the instructions for changing the Brake Light Switch. However pictures in the thread, as well other pictures on the Web, differ from the switch supplied to me from the Dealer. My entire switch is white except for the housing/covering, it is black. Additionally the connection are entirely different. These are two wide tracks with 3 male prongs...... because of this I have three questions;
1) Do any of you have this type of switch? (2000 E55) Is there a difference?
2) Is the procedure for adjusting the plunger length the same in this switch?
3) Is there a tail light fuse that would cause this new switch/lights not to work?
I ask these questions because after changing the switch i still do not have Stop Lights and the BAS/S Warnings are still there of course.
I've not did the battery check, however after following instructions in other threads, my charge/voltage is reading 13+. According to the computer readout of the climate control info. screen.
So I apologize if this is a beaten horse, I'm just doing all i can before submitting car to the shop
