E55 Rear tire premature wear - middle
what do you guys recommend for front and rear tire pressure?
i'm running yokohama AVS DB's that came from the previous owner and they're only about 7k miles old.
Surprisingly the treads look great on outside/inside tread, but I just realized today while looking carefully that the middle of the tread is almost bald. I recall about 2k miles ago it was under inflated and only in the low 20's psi, so i filled it up at the gas station to what it says inside the gas cap. the car's been driving great, but holy cow - the center is bald while the inside and outside treads both still look near new.
p.s. i just checked the front and they look like they're wearing evenly.
there are two #'s that are on the car - one in door frame, and the other inside the gas cap. i went w/ the higher in the gas cap and pumped it up to the mid to hi-40's psi. obviously, i over inflated it. my question is what's everyone else using to get the best best driving and even tread wear.
thx.
I'm pretty shure that MB engineers know what they are doing when the set tires specs.
You do what you want with your car, but don't give out wrong advice to others. I have never seen a rear wheel drive vehicle with tire pressure specs higher in the front and lower in the rear.
The point is, if the numbers you run are causing a lot wear in the middle, the tire fits the wheel, and the balance/alignment are OK, the pressure is too high.
